Old 12-16-2018, 09:31 AM   #1
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
Replacing serpentine belt, has anyone hear of doing this?
I looked up how to change my serpentine belt on YouTube and saw this video about soaking the belt in 303 Aerospace Protectant before installing it. Has anyone ever done, or heard about doing this?
Should I do THIS?
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 12-16-2018, 09:57 AM   #2
chuckie669
chuckie669's Avatar
Drives: 2011 ss
A ratchet was all I needed. Replaced my ac belt too while I wa there. That one sucked
chuckie669 is offline   Reply With Quote
Old 12-16-2018, 10:06 AM   #3
DonM
Camaro #4
DonM's Avatar
Yeah, I saw how easy the serpentine belt was to change, I thought there was only the one belt?
What did you think of using 303 Protectant on the belt?
Don M
Old 12-16-2018, 11:07 AM   #4
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I wouldnt put anything on a belt.
JD555 is offline   Reply With Quote
Old 12-16-2018, 11:37 AM   #5
VickyLyn
VickyLyn's Avatar
Drives: perfectly pink
It is better to check with the car service!
VickyLyn is offline   Reply With Quote
Old 12-16-2018, 02:12 PM   #6
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
Just use a ratchet to shift the tensioner pulley and you can pull it right off, and then pull up a belt schematic on google.
The AC belt is a little tougher, but there is a trick involving putting a zip tie around the belt and one of the spokes of the crank pulley and using a breaker bar to turn the crank.
nUcLeArEnVoY is offline   Reply With Quote
Old 12-16-2018, 03:40 PM   #7
DonM
Camaro #4
DonM's Avatar
I have the V6, I believe I only have the one belt. Whenever I try to look it up it says for the 6.2.
Don M
Old 12-16-2018, 04:15 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Don't put crap on your belt. BTW, why are you changing it?
Old 12-16-2018, 04:20 PM   #9
DonM
Camaro #4
DonM's Avatar
I'm at 91,000 miles. I plan on doing the belt and plugs in the next month or so. Cheap insurance.
Don M
Old 12-16-2018, 04:41 PM   #10
BLU DUCE
BLU DUCE's Avatar
Never hurt to do a little PM=Preventive Matineance.
If spelled right.
Old 12-16-2018, 04:59 PM   #11
Rock-It Man
Can't argue with that at 91,000 miles.
Just don't goop the belt up with snake oil.
Old 12-16-2018, 05:38 PM   #12
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
I know exactly the video you are talking about. He also says to spray your tires tread and all, inside and out. You wouldn't spray it on your brake pedal because it makes it slick. I know what he said in the video, but logic makes me a skeptic. Not like it's a expensive part or hard to put on, so why try it?
Yes the v6 has only one serpentine belt.
Coleroad is offline   Reply With Quote
Old 12-16-2018, 07:26 PM   #13
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
If it makes a brake pedal slippery then it will more than likely make the pulley slip. A good belt will go for a large number of miles without an issue. Don’t put anything on your belts or you will be replacing them sooner than later.
HOJO is offline   Reply With Quote
Old 12-17-2018, 03:34 AM   #14
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Putting it on your belt will let you pants fall down.....
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
