Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
AWE Tuning
Old 07-13-2019, 05:41 PM   #1
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
Stabilitrack/TC at drag strip
SO....im having issues with soft launces at the drag strip. Everything off...double tap...hold for 7-10 sec...tried all modes....still consistent 1.7 at 60'. I can see in my tune that car is pulling timing as soon as I full throttle. I have a ton of tq on race fuel, 763ftlbs, and my tuner thinks the car is seeing this and adjusting the timing because everything is off??? Suggested I pull the fuses to eliminate this possibility. Anyone else run into this? Anyone pulling their Stab/TC fuses for drag racing? Do they need to be pulled and reinstalled in a certain order? Which fuses are they?
Thanks in advance....getting frustrated.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 07-15-2019, 04:10 AM   #2
wnta1ss
Drives: 2017 Camaro 1SS
Has your TCM been tuned?
As far as fuses, in my SS model, the Stabilitrack seems to depend on the ABS fuses, F1 and F22. The power steering does not work and the dash lights up with warnings when these fuses are removed.
wnta1ss is offline   Reply With Quote
Old 07-15-2019, 05:22 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Sounds like Torque Management is intruding on your fun.
Gunkk is offline   Reply With Quote
Old 07-15-2019, 11:22 AM   #4
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
What kind of tires are you running? With that kind of power you should be way into the 1.4x's!!! I am not sure if the torque management is disabled thru the engine tune or the TCM tune... I had my TCM sent out to be unlocked and JRE did all my tuning... consistent 1.42's 60 foot. I am running about 40% ethanol... Similar build besides the ported blower and larger TB
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 07-16-2019, 09:03 AM   #5
meSSohappy
meSSohappy's Avatar
Running MT ETs DRs with 15 lbs and stock front with 42 lbs. TCM has not been unlocked. Best time 10.69 @ 131 mph w/1.71 60’. My dealer said if I tune the TCM all warranty on the transmission and rear end is void. Trying to avoid that. But if it’s the problem with my 60’ then bye bye warranty. If I look at all my data logs, I have the exact same timing curve at launch. It drops right off at the start. Only lasts for milliseconds but it’s enough to soft launch the car.
Old 07-16-2019, 09:08 AM   #6
meSSohappy
meSSohappy's Avatar
It was mentioned in another group on FB that this box highlighted in red should be turned to enabled. Mine is currently disabled. Have my tuner looking into it. It is done through ECM tune, not TCM, so that’s good. Thoughts?
Old 07-16-2019, 09:34 AM   #7
2018ZL1
2018ZL1's Avatar
Mine is set to enable...
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
Old 07-16-2019, 10:06 AM   #8
meSSohappy
meSSohappy's Avatar
Ok. Cool. I will change mine and see what happens.
Old 07-16-2019, 10:25 AM   #9
2018ZL1
2018ZL1's Avatar
If thats what the issues was you are in for a BIG surprise!!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
Old 07-16-2019, 06:49 PM   #10
meSSohappy
meSSohappy's Avatar
I sure hope so....sub 10.5 would be nice !!!
Old 07-16-2019, 07:03 PM   #11
meSSohappy
meSSohappy's Avatar
For you guys that have the HP Tuner set up as pictured above, are the other values in the pic the same settings as your personal tunes? Just wondering if I ENABLE IT of other values are affected.
Old 07-18-2019, 04:03 AM   #12
wnta1ss
I think that is probably a big contributor to your car's launch problem. TCM tuning might be needed to fix your problem, sounds like there's too much torque management going on.
Old 07-22-2019, 02:57 PM   #13
meSSohappy
meSSohappy's Avatar
I didn’t make a difference at all. Looks like I will need to unlock my tranny to get rid of all torque management.
Old 07-22-2019, 03:23 PM   #14
2018ZL1
2018ZL1's Avatar
That wouldn't surprise me one bit! I would have thought the power train warranty would have been blown to pieces with the mods you have done so far! Adding all that extra HP if that locked tranny fails I have a sneaky suspicion they wont be covering it! I can tell you its a PITA to remove it!! lol the entire front end of the car has to come off... just a couple screws!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
