Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 03-17-2018, 09:38 AM   #1
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Radiator flush help
How far does the petcock turn to drain the radiator?
Mine in closed position is parallel to the ground. Did not turn easily but I did turn it 90 degrees counter clockwise so that it now sits perpendicular to the ground.
Looks like it needs to be turned more to flow but I dont want to break it.
Help is appreciated.
chuckie669 is offline   Reply With Quote
Old 03-17-2018, 09:44 AM   #2
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Please disregard. Got it after my friend channel locks showed up. Had messed up my hand in accident earlier in the year and my girl like grip strength was not enough to wrestle the beast.
Thanks all
Old 03-17-2018, 10:17 AM   #3
DSMer1
Drives: 14 and 15 SS's
Thanks all
Some girls have a very healthy grip.
DSMer1 is offline   Reply With Quote
Old 03-17-2018, 10:23 AM   #4
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Zing
Old 03-17-2018, 06:52 PM   #5
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
I avoid flush solutions. I just drain, fill with distilled water, let it run for a few minutes, drain and repeat if needed. Distilled water will pull out any crap that's in there without causing harm. Make sure not to use tap water when refilling.
A lot of coolant stays in the heater core and block, this is why I drain, refill, and repeat if the coolant looks a bit murky. I also wouldn't want to leave any corrosive flushing solution behind...
TWOFORTYZ is offline   Reply With Quote
Old 03-17-2018, 08:03 PM   #6
chuckie669
chuckie669's Avatar
Drives: 2011 ss
No worries. I just didn't want to break the petcock twisting it first time in the camaro. All good now.
Gonna contact one of dsmer1 girls next time I need to open it.
Old 03-18-2018, 04:55 AM   #7
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
Petcock comes completely out. Mine came out with just my fingers.
polizzio is offline   Reply With Quote
Old 03-29-2018, 07:28 AM   #8
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
I usually disconnect the hoses at both ends and use a garden hose to flush out the radiator, then reattach the hoses and fill with new fluid.
ZEN357 is offline   Reply With Quote
Old 06-02-2019, 06:44 PM   #9
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
What if petcock wont re-tighten? Is it possible to strip it? if its broke it should pull out but it doesn't.
Anyone had this happen?
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
