Old 04-25-2015, 04:53 PM   #1
JDMAC
Drives: 2015 Laguna Blue C7
Fuel Access Door
I am wondering if there is a difference in operation of the fuel door between the 2014 and 2015.
If you watched the "How To Video" on you tube the door is not suppose to open until the driver door is opened. This is on a 2014.
This is how my 2015 works.
Fuel door opens with driver door open or closed when the door is unlocked.
Fuel door will lock when the car door is locked.
When the driver door is unlocked with the FOB, fuel door unlocks.
If you open the driver door when the door is locked without using the FOB the fuel door also opens when the driver door is opened.
I have looked in the settings but have not found any setting pertaining to the fuel door.
Not a big problem, just a curiosity question.
JDMAC is offline   Reply With Quote
Old 04-25-2015, 10:19 PM   #2
Joe Stingray
Joe Stingray's Avatar
Drives: 2019 Stingray 2LT
well I have a 2015....an mine operates like you have described above.....and I have seen NOTHING within any of the menus'....which leads me to believed that's just the way it works.....no settings to change or to select.
Joe Stingray is offline   Reply With Quote
Old 04-26-2015, 04:20 PM   #3
JDMAC
Thanks for your feed back. I was pretty sure that this was normal. Just wanted to see if anyone saw something different.
Old 05-11-2015, 10:29 AM   #4
route66
Drives: 66 coupe 78 pace car 2014 coupe
I have a very early 2014 and mine operates the way you described.
route66 is offline   Reply With Quote
Old 05-19-2015, 09:44 PM   #5
meyerweb
Drives: 2015 Black over DSOM convertible
Basically, if the driver's door is unlocked, the fuel door is unlocked.
meyerweb is offline   Reply With Quote
