07-24-2015, 07:18 PM | #1 |
Drives: Midnight Blue Camaro SS Join Date: May 2015
Rear wheel problems
So I noticed that when I do burnouts I have traction from both tired but then when I try to do some doughnuts I'm only one legging it ?!
Do you guys have any idea what that might be ? Anything helps thanks |
07-24-2015, 09:12 PM | #2 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Its not a problem, it's the nature of the Posi-traction/Limited Slip Differential. When doing a burn out in straight line, power/torque is distributed equally to both wheels. When you are doing a donut, the weight and G-forces are shifted to one side and differential compensates for this by shifting more power to one wheel then the other. I know there's a more technical explanation, but basically, the differential is doing what it is designed to do. I'm sure other's will chime in with a better explanation and more help.
07-25-2015, 12:31 AM | #3 |
Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
You have traction when doing burnouts? Something is definitely wrong there.
5th gen, camaro, camaro ss, camaro ss differential, l99 engine |
