TireRack
Old 03-10-2014, 08:10 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
M5 Meth ?
I have meth injection on my 2013 1LE with a ECS kit @ 10.8 lbs. boost. Car has been sitting in the garage all winter with about a gal. of M5 in the tank. Has anyone had problems with M5 attracting moisture ? I went for a ride tonight and car seam to have a small backfire & stumble when coming into boost. The first thing that came to mind the M5 was trash. Any help with this would be much appreciated.
Craig B is offline   Reply With Quote
Old 03-11-2014, 08:52 AM   #2
Frost
Frost's Avatar
Drives: GM anything
It can go bad... it's quite hygroscopic and the tanks typically have breather holes open to the atmosphere. Just drain it; it will only take you a few minutes and it's cheap peace of mind. It could be the issue you have encountered as well...
Frost is offline   Reply With Quote
