03-23-2014, 07:49 PM | #1 |
Drives: 2013 1LE Join Date: May 2013
Do I need a new tune??
I will soon be doing my 2nd cam swap on my 1LE. The current cam is a 227/235 with 115 L/s. I will be installing a custom cam that was designed for FI. The specs. are 226/246 with 117 L/S. I also installed 3 inch exhaust a few months after I had it tuned. Will it need to be tuned right away?? I am thinking yes, but would like to confirm with some people in the know. Thanks in advance.
03-24-2014, 08:20 AM | #2 |
Drives: GM anything Join Date: Sep 2009
That's a subjective question
Can you start it up on the new cam and drive it around EASY until time for re-tuning? YES! Avoid heavy or WOT until it goes back on a dyno and with a wideband but you should be fine. Your fueling (if not a hack tune the first time around) should stay relative close at heavy throttle but timing needs will change a bit. It might even BE ok at WOT; but no need to take that risk until you get the tuning updated. |
03-24-2014, 05:44 PM | #3 |
Good to know, thanks for the info.
03-24-2014, 08:46 PM | #4 |
Drives: 2010 Camaro Join Date: Mar 2014
different cam different characteristics different tune
04-06-2014, 01:31 AM | #5 |
Drives: 96SS Join Date: May 2009
Give us a call if you need a dyno tune.
