01-31-2014, 11:49 AM | #1 |
Forgive the oldschool stupidty.
If replacing the engine can you get a basic mailorder tune to get the thing going again and enough to travel to a shop to get car setup and a thorough dyno/street tune? Also have an SCT Handheld that came with Supercharger that is sitting on shelf collecting dust. Thx
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly |
02-03-2014, 01:00 PM | #2 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
If the new engine is comparably setup to the old engine (ex. injectors, cam, etc.) then yes. The more mods and/or the larger the change, then the likelihood diminishes.
To elaborate, let's say that you have 35# (pounds per hour) injectors, and the computer thinks you have 35# injectors. All is good. But, if you change them to 70# (twice the flow as before), but the computer doesn't know this, you'll end up with 2x the amount of fuel being injected. The fuel trims can only compensate like 20%, not 200%.
Jack Bilger
02-03-2014, 01:10 PM | #3 |
OK so if going from 376 FI cammed etc with app 65 lb injectors to a 415-418 with 80-85, it's probably better safer to tow it tune it then waste money on mailorder?
Thanks for the reply.
02-03-2014, 01:38 PM | #4 | |
I did the supercharger, cam and headers all at the same time. Mail order tune got me safely started.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
02-03-2014, 06:11 PM | #5 |
Drives: 2010 RS/SS Join Date: Dec 2010
Get in touch with your tuner and have them do a base file for you. We do it all the time...customer has too radical of a set up to drive to us, so they send in their ECM ahead of time, we flash it, then they drive to us to finish up the tuning. It's also nice so you can start/shake down the car before it gets to the tuner - in case something else needs attention before tuning.
02-03-2014, 10:23 PM | #6 | |
Drives: GM anything Join Date: Sep 2009
02-04-2014, 08:45 AM | #7 |
Thanks.
02-04-2014, 01:44 PM | #8 |
Cory
Drives: 2010 Camaro 2SS/RS M6; Join Date: Nov 2009
Glad to see this thread. Getting ready to change my fuel system and put a TT setup on the car, reading this will help me get along a little better.
02-04-2014, 04:24 PM | #9 |
Drives: 2010 M6 2SS Join Date: Mar 2011
Just please don't go bananas with it on a tune like that...if you've got a good tuner, you're probably going to have something safe enough to drive agressively with, but don't risk it as there's too much money tied up in an engine...if they get you a tune that starts and idles ok, and you can let the engine get up to temp with nothing strange going on...just take it easy on the go pedal while you drive it to the dyno.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
