Vararam
Old 01-23-2013, 12:35 AM   #1
LG_23
LG_23's Avatar
Drives: Camaro SS
Cool How Fast would a LS7 Camaro be?
Assuming the rumors are true, and it has the same 505 HP from the Z06. How fast would it be? Am guessing a bit faster than a Challenger 392 and on par with a Boss 302.
LG_23 is offline   Reply With Quote
Old 01-23-2013, 02:11 AM   #2
AdamZ
Not much different than an ls3
Old 01-23-2013, 03:10 AM   #3
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
The 392 I believe is just as fast as the boss 302 if not a bit faster from the stock time slips I've been seeing. So saying that, a camaro that is lighter than the 392 with 35 more hp will be faster than both. All in all, it's still a drivers race but you would have a small advantage.
K32 Camaro is offline   Reply With Quote
Old 01-23-2013, 03:53 AM   #4
CRTZL1
Drives: 2013 CRT ZL1
Not faster then a ZL1!!
CRTZL1 is offline   Reply With Quote
Old 01-23-2013, 04:14 AM   #5
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
High 11's
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 01-23-2013, 05:34 AM   #6
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
here is a video of one during a night test, judge for yourself
http://youtu.be/L5bPu58fSc0
05stram is offline   Reply With Quote
Old 01-23-2013, 07:20 AM   #7
SWAT
Drives: 2011 2SS RS L99
SWAT is offline   Reply With Quote
Old 01-23-2013, 07:53 AM   #8
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
It would be a bit faster, more cubes and more power though out the rev range. I would say easy mid to lower 12 car so about .5-.7 faster then a avg stock ls3 car. But really no reason for anyone to go and sell your ls3 camaro for a ls7 camaro Not worth it in my opinion! Now if I did not own a camaro and I was in the market, an LS7 camaro would be on my list.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-23-2013, 08:40 AM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I think high 11's too, good prediction.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 01-23-2013, 09:40 AM   #10
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
So and extra ~70hp and torque from the engine will not provide any sort of meaningful difference in speed and pefromance? Why do people put aftermarket cams in their cars to the tune of ~50rwhp gain if all that power makes no difference in how fast their car is over stock?
LIVEVIL is offline   Reply With Quote
Old 01-23-2013, 09:46 AM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
If true....
The benefit of an LS7 would be most noticed around the track....if coupled with the 1LE suspension. What it allows them to do is add 80hp and a higher redline (for racing), without effecting an ounce of weight or weight balance. While it's larger displacement, all small-blocks are the same physical size (comparing car-to-car, and no sueprcharger ).
I'm sure it'd cut off half a second or so at the drag strip, too.
Old 01-23-2013, 09:51 AM   #12
Pro Stock John
Writer
But the increase would not only be in terms of peak hp, but also overall hp across the curve, as well as a big increase in torque.
I think a drop of a full second if not more. A Camaro is perhaps 600 lbs heavier than a C6Z. They can run mid 11's in the hands of good but not amazing drivers (been done many times). Now add 600 lbs. 11.5@124 becomes 12.1@118. Something like that.
PROJECT HEAVY CHEVY
Old 01-23-2013, 09:55 AM   #13
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
I think that's right. A ZL1 runs high 11s, so I'd say mid 12s for a LS7 Camaro. But first GM would have to actually build this car...
SS 376 is offline   Reply With Quote
Old 01-23-2013, 11:50 AM   #14
LOWDOWN
Downright Upright
Drives: Daily
Originally Posted by Mr. Wyndham View Post
If true....
This...
Predicting a hero time for 1/4-mile running, imho, would be less important for something akin the so-far-unannounced ZEE than what time it could run @ VIR in Lightening Lap circumstances...which surely would be sub-3:00...
But to "answer" the question: low-to-mid 12s, depending on driver talent...
LOWDOWN is offline   Reply With Quote
427, camaro, ls7, z28
