TireRack
Old 01-31-2014, 11:59 AM   #15
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Originally Posted by Frost View Post
The AEM unit is the bottom of the barrel for consumer widebands. The AFX has the internal "guts" (controller) of a notably more expensive (and more accurate) unit, has free-air cal to extend useful sensor life (the AEM wanders off; it's cal tied to it's laser etched cal-resistor from the factory that is unchanging, unlike the sensor), and will run (and include if you get it from the right place) the NGK sensor instead of the Bosch cheapie that other units use. The NGK has a fixed 0-5VDC output for hooking up to your HPTuner's cable.
That is disappointing. I should have done more research.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 01-31-2014, 02:38 PM   #16
thahemp
Geek
thahemp's Avatar
Example of what Frost is talking about. Really wish I would have seen this earlier.
http://www.hptuners.com/forum/showth...-Try-Something
x = ~x
Old 01-31-2014, 04:21 PM   #17
B-_-RAD
Drives: ...
I actually got mine up and running last night and it was easy. I made a custom PID but ended up using the standard lc-1 input in HPT since it was dead on. Never would have guessed it would be so easy.
B-_-RAD is offline   Reply With Quote
Old 01-31-2014, 07:31 PM   #18
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
My Autometer WB/Lambda gauge uses a Bosch sensor but had no offset into HPT that I had to compensate for. 0-4v output needed a custom PID. I think & tune in Lambda as that was how I learned years ago. Works best for alternate fuels. Pod mounted the gauge on the column using an SLP pod.
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 01-31-2014, 10:09 PM   #19
Frost
Frost's Avatar
Drives: GM anything
It's perspective though, because all of these units are measuring in lambda and then converting to AFR based on a fixed fudge factor for 'known' stoich, so even when you think you are tuning by AFR...
Frost is offline   Reply With Quote
Old 02-01-2014, 01:15 AM   #20
B-_-RAD
Drives: ...
Lol. I wish it was feasible some day I would be as knowledgeable about tuning with hp tuners as you are...
Old 02-01-2014, 01:38 AM   #21
thahemp
Geek
thahemp's Avatar
The analog output is lambda. AFR is just another way of viewing the same data. Dedicate yourself to the cause. There is no reason that you can't get to his level. He us just ahead of you in time.
x = ~x
Old 10-24-2014, 10:23 AM   #22
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
In answer to the OP's original question, I tried pin 47 and could not get it to work. Tried pin 55 on the gray connector and bingo: AFR voltage into my EFI live scans over the EGRS PID.
Your tuner has to turn the EGR functionality on in your tune for this to work.
