Old 02-24-2018, 12:26 PM   #1
Miami_1LE
Drives: 2018 Camaro SS 1LE
Vibration During Acceleration
2018 SS 1LE is vibrating during acceleration. More noticeable in gears 3 and up. Also vibrates around 60-70mph in 6th when I let off the gas. Anyone have the same issues.
Miami_1LE is offline   Reply With Quote
Old 02-24-2018, 12:33 PM   #2
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Auto or manual? Do you feel the vibration in the steering wheel mostly, or the whole car? Any mods? No issues here.
torqueaddict is offline   Reply With Quote
Old 02-24-2018, 06:57 PM   #3
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
He's manual with it being a 1LE.... OP hard to say I would take it in to be looked at. That doesn't sound good.
qcman is offline   Reply With Quote
Old 02-24-2018, 08:46 PM   #4
Wierd Harold
Drives: 2017 2lt rs
Description sounds like driveshaft troubles.
Wierd Harold is offline   Reply With Quote
Old 02-25-2018, 12:39 AM   #5
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
What's the vibration frequency, where does it sound/feel like it's coming from, and is it consistent with the relation to speed. Does it vary with engine RPMs.
I just had a vibration issue at 60-70mph end up being the wrong wheel installed in front.
protovack is offline   Reply With Quote
Old 02-26-2018, 03:51 PM   #6
Miami_1LE
Its in relation to the speed. Sounds like its coming from the rear. And I get vibration in the steering wheel, pedals, and ass. The vibration is not something out of this world but I do know its not suppose to be there. I'm gonna jack her up and check out the axle bolts. I take really good care of my car and don't beat the hell out of it. Also, lets say I'm in 3rd gear at maybe 2000rpm, if i floor it i get vibration while going up through the rev band. All gears feel like this, and is mostly felt in gears 2-4 because that's where I usually hit it.
Old 02-26-2018, 05:19 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If it's related to land speed, the first place to look is wheels and tires. 2nd choice, drive shaft and flex coupling, but only if the vibration goes away in neutral.
Old 07-05-2018, 11:44 AM   #8
appleman22
Drives: 2017 1ss 1le
Any update to this? What fixed it
appleman22 is offline   Reply With Quote
Old 07-11-2018, 10:52 PM   #9
ht600
ht600's Avatar
Drives: 2019 Camaro ZL1
I would like to know too. I have the exact same problem on my 2017 1LE.
ht600 is offline   Reply With Quote
Old 07-12-2018, 12:16 AM   #10
protovack
Again, this sounds like it was a wheel/tire balance issue.
The first question is, have you gone to a good independent tire shop and had them road force balance all wheels from scratch?
Don't trust a balance job from the dealer, I've learned.
Old 07-12-2018, 12:23 AM   #11
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Mine does it too at part throttle.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-24-2018, 12:50 PM   #12
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
just bumping this post because I'm having this same issue.. 3-4 gears
Twoblindsheep is offline   Reply With Quote
Old 07-24-2018, 02:27 PM   #13
torqueaddict
Agreed, start with the simple stuff first. With my last car, I quit having the dealer balance it because they never got it right. My guess was their machine needed maintenance. Had to take it to another shop.
Old 07-24-2018, 07:33 PM   #14
yotaman96
yotaman96's Avatar
Doesn't seem like a wheel or tire issue. It only happens at part throttle for me. No vibrations while just cruising.
2002 Trans Am
