Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > Canada
Old 05-30-2016, 09:42 PM   #1
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
Tpms relearn tool or cost
Anyone locally to Burlington have a relearn tool for the tire sensors? After reinstalling my zl1 wheels the tpms light came on. Apparently you need to tool for this. I was hoping the computer would remember them. My wife's challenger did. Didn't really want to spend at least $100 for a tool that I will use maybe once a year.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 05-30-2016, 09:49 PM   #2
BALLEE
BALLEE's Avatar
Drives: 2010 2SS LS3
In my 2010 you can reset the tpms sensor through the dash menu. It will beep once then it front left take some air out till it beeps again, front right , rear right and last rear left. Then once its all done it will beep twice.
BALLEE is offline   Reply With Quote
Old 05-30-2016, 09:50 PM   #3
Cavalo Preto
Cavalo Preto's Avatar
Drives: 2011 ss2 convert
Don't think you need a tool just move the menu to the pressure setting and hold the rest until your horn honks and tells you to move along on each tire mine worked like that there are a few videos on you tube also ����
Cavalo Preto is offline   Reply With Quote
Old 05-30-2016, 10:29 PM   #4
Mike14bumblebee
Apparently that doesn't work on 2012 and later models. Mine being a 2014. I tried it multiple times and just about let all the air out of drivers front tire with no horn honks lol. Then I did more research to find that gm changed the relearn and a tool is now required. Must be a money scam lol. Thanks for your replies though
Old 05-31-2016, 06:16 PM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
My 2012 the relearn procedure was just like stated above...you need to either increase or decrease the pressure a certain amount i think by 15psi? However if the wheels were off your car for a long time maybe the internal battery on the tpms isnt charged up? It took my car about 100km's once before the tpms relearned itself. Im guessing the sensors charge up on there own as the wheel spins.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 06-01-2016, 11:29 AM   #6
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Yup. My 2012 worked with the above procedure, too. That being said, it's a 12/2011 production, though.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 06-16-2016, 01:27 PM   #7
cabbe
Drives: 2014 2ss 1le
I think from 2013 and on you need the relearn tool
cabbe is offline   Reply With Quote
Old 06-16-2016, 01:44 PM   #8
Libertypilot
Libertypilot's Avatar
Drives: 2013 Silver Ice Metallic
I just got new wheels for my 2013 and the seller said, "I shouldn't need" the relearn tool. But then they sent me this attachment and told me if I do need it, to follow the instructions. I'm certainly going to try all of the above before buying this tool, including charging the new sensors simply by driving my car.
File Type: pdf ORO-TEK TPMS Sensors - TPMS Reset Procedure.pdf (62.2 KB, 368 views)
Libertypilot is offline   Reply With Quote
Old 06-16-2016, 09:52 PM   #9
Mike14bumblebee
I tried multiple times and after driving many kms. I ended up buying the tool, well my wife bought it for me for Father's Day ��. Best 100$ she spent lol. Took me longer to find a 9v battery for it then it took me to relearn the sensors with the tool. Figured I'm gonna use it twice a year so might as well buy it.
Old 06-18-2016, 10:38 AM   #10
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
I just bought a snapon TPMS3, works mint.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
