AWE Tuning
Old 04-07-2019, 05:56 PM   #1
GA SS
Drives: 2017 ZL1
9.8 Quarts of oil not 10?
I just got my last free oil change and the dealer let me upgrade to the 0w 40 ESP Mobil 1 for a small fee.
The tech said the computer had him put in 9.8 quarts not 10. He did give me the rest of the last bottle. I know this isn't much difference, but I thought it was supposed to be 10 quarts even. Has anyone else heard that 9.8 quarts fills the 2017 ZL1?
GA SS is offline   Reply With Quote
Old 04-07-2019, 06:05 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I have a 2017 ZL1 and the manual says 10 quarts and my 2016 SS also took 10 quarts with a filter change!
LT4Greg is offline   Reply With Quote
Old 04-07-2019, 06:07 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
The capacity of the oil in the car has nothing to do with how much you should put in. Because you never know how much is left in there even if you let it drain for an hour or so. Several ounces are stuck to the sides and on other components. Find out what the capacity is in the owners manual, put in 90% of that amount. And then start putting in 2ounces at a time until you are mid stick.
Old 04-07-2019, 06:43 PM   #4
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
I used 11 my last oil change.
greaser2 is offline   Reply With Quote
Old 04-07-2019, 06:44 PM   #5
PROMETHEUS
PROMETHEUS's Avatar
Drives: 2019 ZL-1, Shadow Gray, Sold
I used 10.5 in mine and that was after I let in drain for well over 30 mins.
PROMETHEUS is offline   Reply With Quote
Old 04-07-2019, 06:57 PM   #6
DangerZL1
Drives: 2023 Black ZL1 Auto
That’s good they only put in 9.8 qts. I’d rather have them under fill it than over fill it.
DangerZL1 is offline   Reply With Quote
Old 04-07-2019, 07:11 PM   #7
LT4Greg
LT4Greg's Avatar
I go by what the owners manual states and haven’t had any problems yet!
Old 04-07-2019, 08:05 PM   #8
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Does the ZL1 not call for 11 quarts?
seanblurr is offline   Reply With Quote
Old 04-07-2019, 08:10 PM   #9
Artos
Artos's Avatar
Drives: A10 LT4
I thought all the 6.2's in the Camaro lineup were Tenqts....all my changes took the stated 10
Artos is offline   Reply With Quote
Old 04-08-2019, 07:25 AM   #10
LT4Greg
LT4Greg's Avatar
10 quarts!
Old 04-08-2019, 08:41 AM   #11
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
No, manual shows 10qts for the LT1 and 11qts for the LT4
I would just check one morning before starting and see if it shows full on the dip stick. Two tenths of a quart is not going to matter one way or the other if it was a 10 quart system. However, the LT4 show that is has a 11qt. system..
Again, just check it when it has had time to properly drain back to oil pan and see if you need to add that last bit of oil and if you need to add another quart based off the manual.
PS: What was the difference in price if you don't mind being asked?
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 04-08-2019, 09:06 AM   #12
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Did my 500 mile change, took 10 quarts. No more, no less
gotswap is offline   Reply With Quote
Old 04-08-2019, 10:05 AM   #13
travislambert
travislambert's Avatar
Drives: '17 ZL1
11 quarts is the coolant capacity, not the oil. The LT4 oil capacity is 10 quarts.
I'm pretty sure it makes no difference if you have 9.8 quarts, 10 quarts, or even 11 quarts of oil. However, I'd recommend if you track your car, a little extra is better/safer. The last thing you want is to starve the system for oil while taking a hard corner (It happens, especially with sticky tires.)
If absolute precision were required with respect to oil capacity, GM would engineer a better solution than the dipstick that's nearly impossible to read with clean oil.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 04-08-2019, 11:30 AM   #14
DANACO
DANACO's Avatar
Drives: 18 ZL1
This is bad advise regarding “or even 11” you put the recommended amount in, run it, wait 15-20 minutes, check the level, period. Over filling can damage an engine, the specified amount is was not a guess by the engineers, it’s specific for many reasons.
DANACO is offline   Reply With Quote
