Roto-Fab
Old 06-29-2013, 10:40 PM   #1
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
Beware the side curtain air bag deployment algorithm!
Your SS side curtain air bags can deploy WITHOUT an impact and while all of your tires are still contacting the road. Don't know if the SIR computer's anti-roll algorithm is the same for the V6, LE or ZL1 models. As a minimum result and to replace with new, you are looking at 2 new air bags (there was a front seat passenger), 2 new seat belt assemblies, new SIR computer module, and a deformed head liner. GM list price for all the parts except the headliner total to about $1500. Add a new headliner and that adds about another $400.
I know the video has already been posted showing the silver Camaro drifting in the parking lot and his side curtains deploy. Here's the details of another account:
During some spirited driving and exiting a right hand corner on a fairly level asphalt road, the driver's side wheels hit some loose stuff while the steering wheel was not yet fully straight. The result was the car quickly rotated from left to right (about 60 degrees of yaw) and the car slid laterally down the road - all of this while the car is still on the road surface. Remember, less friction always "leads". To correct the slide, the the driver started to turn the steering wheel to the left and into the slide. At this moment, the 2 side curtain air bags were immediately deployed by the SIR computer. Needless to say, that shocking and unexpected event broke the driver's concentration and made a small issue a huge problem. By 'broke driver's concentration', I mean going from 'turn the wheel to correct this slide' to 'why the hell did my side curtain air bags just inflate!?'. Luckily, when the car then ended up leaving the right hand side of the roadway, it only spun around on some level ground (no trees, poles, ditches, etc) or this could have had a much different outcome.
Some of the tech details: stock suspension (other than the addition of a GM front strut tower brace), suspension in good shape, dry asphalt road, hot day, about 80 mph, 1.7 Gs, and up to 40 degrees of body roll when the computer anti-roll algorithm said "lock the seat belts and deploy the side curtain air bags". Even with a loading driver's side suspension, not sure the car can have 40 degrees of body roll without at least one wheel lifting off the road surface. Repeating, the wheels did NOT lift off the road - the car was sliding laterally down the road. Of course, the same device that deployed the air bags (based on an algorithm calculation and not any impact sensor) is the same module which was utilized to record some data and determine it "functioned normally" - hardly an independent verification.
It's interesting when you talk to others on and outside the forum which have had side curtain bags deploy in similar situations (no sudden jolts to the wheel/suspension, no body impact or crash, driving down a road during cornering or exiting a corner, ...), their story is very familiar and it sure leads you to the conclusion the anti-roll algorithm is set to deploy too sensitively for spirited driving. For pete's sake, this is a Camaro, not an SUV!
Just wanted to alert all to what can happen - better to be forewarned. Be safe!
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 06-29-2013, 10:59 PM   #2
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Happen to me had stabilitrac turned off and was playing around. Car did a 180 and the side curtains deployed.
Inferno LSX is offline   Reply With Quote
Old 06-29-2013, 11:48 PM   #3
cam45
cam45's Avatar
Drives: 45th anniversary 2LT/RS
I've heard of these events and I was wondering if GM take care of the cost? That's a hefty price for deploying for no reason
cam45 is offline   Reply With Quote
Old 06-30-2013, 07:42 AM   #4
mySSt
mySSt's Avatar
Nope, GM won't pay for any of it. They collect the data from the SIR module and then tell you "the system functioned normally."
Old 06-30-2013, 09:01 AM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
I've done some airbag deployment work in my career. A lonnnnngg time ago but it applies.
In order for the airbag to do anything it has to be deployed. If you don't make the decision to deploy soon enough it won't be there when you need it. So you have literally milliseconds to determine if the conditions are leading to crash. So for every move you make to avoid this condition you are likely finding more conditions where it should have deployed and did not.
I was at a different OEM at this time, but there is generally a "NO FIRE" event, a "MAY FIRE" range and a "MUST FIRE". So based on the accelerometers available there is a set of parameters under which the airbag should never go off and there is another range where it must ALWAYS go off. It's the range in between that gets very hard to calibrate.
Right or wrong, GM has chosen these parameters/conditions and they aren't likely changed because of the type of car.
So yes, the car likely performed as engineered in these types of events.
Old 06-30-2013, 09:30 AM   #6
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
So if you do some donuts they're going to deploy?
its a syn is offline   Reply With Quote
Old 06-30-2013, 09:42 AM   #7
oldfriend
Drives: Fiat 500 E
Go ahead and do it , then let us know
But if they do deploy , don't send us the bill !
oldfriend is offline   Reply With Quote
Old 06-30-2013, 09:47 AM   #8
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Once they deploy, you don't have to worry about them any more. Just don't get into any wrecks after that!
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 06-30-2013, 09:54 AM   #9
Synner
Drives: cars
Considering the loss of traction it seems like a valid deployment, 1.7G's is a crap ton. The majority of people out there are too poor of drivers to recover the vehicle themselves in such a situation. It just sucks for people who know how to correct significant oversteer.
Synner is offline   Reply With Quote
Old 06-30-2013, 10:44 AM   #10
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I have spun mine around a few times... I think I'll stop doing it after reading this! Number 3 makes excellent points. Tiny windows of data are sometimes impossible to draw accurate conclusions from. Just a case of better safe than sorry.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-30-2013, 11:02 AM   #11
mySSt
mySSt's Avatar
Thanks for the input. Agree that its a decision they built into the computer algorithm to cover the "majority of drivers" - just like producing cars with built-in understeer (instead of neutral or oversteer) since it keeps the manufacturer's liability lower. However, its a shame that the type of vehicle doesn't make a difference in the firing point calculation for the deployment (lower center of gravity, car's ability to respond quickly to steering input, ...). Sure bites this is all about a roll over PREDICTION calculation versus an impact to a sensor to deploy front air bags for example.
Old 06-30-2013, 11:06 AM   #12
firedrop
Drives: 2012 2ss/l99 a6, victory red
why would you want to do donuts in your car anyway? unless youre rich, and at that point who cares if the airbags deploy? $1,500 should be nothing to you if you're doing donuts on $350+ tires.
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s
firedrop is offline   Reply With Quote
Old 06-30-2013, 11:10 AM   #13
thahemp
Geek
thahemp's Avatar
Because donuts are fun? Why do we need 400+ HP cars? It's not like there is legal place to stretch our legs anyways.
::EDIT::
Besides on a closed course obviously.
x = ~x
Old 06-30-2013, 11:38 AM   #14
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
At 1.7G's and 40* list and 80+mph it seems like a normal event to me,the computer thought the driver had lost it and a crash was inevitable and he probably had lost it.
If your going to drift something pick something with less technology.
BTW anyone see the vid of the Hennesey CTS-V catapult launch on the dragstrip where Onstar thought they had been rearended because of the launch G's?
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
