Old 04-22-2014, 02:49 PM   #1
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
Turn your LS2/LS3 into a Stage 3 LS7-LSX
Here is an example of a recent customer build taking a LS2 block and putting a sleeve in it to push the bore to 4.130. This package allows an LS2 car to be morphed into a pumped up LS7 and still retain the compatibility with the stock LS2 base engine.
This package is based around a custom sleeved LS2 block that Livernois Motorsports machines in house on its own 4-Axis CNC machine. This allows absolute precision and ensures the block is held to within just +/- .0001 to the specification.
Once the block machine work is done we utilize our own custom rotating assembly, complete with forged H-beam connected rods, forged custom pistons, stainless steel top ring and Napier second, upgraded thick wall wrist-pin and forged stroker crankshaft. This takes us to a 429 cubic inch size.
The short-block is then complimented with LSX-LS7 heads utilizing our own custom CNC program and valve-job, along with the FAST composite intake. This package is designed for the ultimate in street-able performance from a large cubic inch LS base. The added cubic inches and breathing from the bigger bore, coupled with the longer stroke and high flowing cylinder head matched with custom camshaft really turn this engine into a beast.
Short-block, Long-block and Complete engine packages just like this are available to retrofit your LS2 and LS3 equipped car into a big-bore stroker LS7 monster with direct bolt-in capability.
Livernois Motorsports is offline   Reply With Quote
Old 04-22-2014, 02:54 PM   #2
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Wow that's bad ass did not know it could be done safely. Great news
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 04-22-2014, 02:58 PM   #3
firedruish
Guest
Posts: n/a
What is the cost of something like that? Is there a mod for the v6? How does that compare to the Hennessey. ..or..Calloway upgrades?
Old 04-22-2014, 04:05 PM   #4
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Darton makes a sleeve kit for the 3.6 that will allow a max bore of 98mm which would make the v6 engine roughly a 3.9L... I bet Livernois could install the sleeves... The sleeves themselves are $1825 msrp, but then you'd have to get custom pistons made, plus labor... Could be spendy.
That's some nice looking engine porn there Livernois guys!
Jason@JacFab is offline   Reply With Quote
Old 04-22-2014, 07:21 PM   #5
mikeyg36
Drives: 2015 Z/28 #533
What's the cost on something like this?
Old 04-23-2014, 01:25 PM   #6
Guys,
This is definitely a sweet build and a great option for you LS2/LS3 guys. To get pricing for a build like this shoot us a PM or give us a call at the shop for pricing. 313 561-5500.
Old 04-23-2014, 01:31 PM   #7
As for the V-6 option what are you looking to do your car as far as performance goes?
Old 04-23-2014, 03:21 PM   #8
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
How about L99 to 427c.i.? Is it possible to do that?
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 04-23-2014, 04:22 PM   #9
Unreal
Drives: 2006 Z06
Yes it is. You can go from a 4.8L to 427 or 440 if you wanted with a sleeved block.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 04-23-2014, 05:04 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by Livernois Motorsports View Post
Guys,
Sounds nice!
I am considering your mini stroker 390 short block next spring!
62nalide is offline   Reply With Quote
Old 04-23-2014, 08:27 PM   #11
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Do the LSX-LS7 heads have a better reputation for valve guide wear then the regular production castings? Are the intake valves still titanium?
Would also like some more info on your mini stroker. Is it an offset ground factory crank with honda rods? What kind of compression ratios are available with it? Thanks!
Irnwkrkev is offline   Reply With Quote
Old 04-23-2014, 09:18 PM   #12
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
So I could do this to a ls6 block?
-John S.
grocerygetter is offline   Reply With Quote
Old 04-23-2014, 09:56 PM   #13
flashtech
flashtech's Avatar
Drives: '10 2SS/RS '04 NSRT-4 '06 F-150 V8
What is the hp rating at the crank on this setup?
flashtech is offline   Reply With Quote
Old 04-24-2014, 03:33 AM   #14
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Curious to see the HP and TQ numbers on a build like this ?
Sapper12b is offline   Reply With Quote
