Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 10-31-2013, 07:49 AM   #1
MADBADGER
Drives: '13 Camaro 2SS/RS
Survey: Your Oil & Filter
I would like to conduct a survey of what oil brand and grade you CURRENTLY have in your car, along with the oil filter.
I do not care what you THINK is the best oil or filter, when you change the oil, whats dexos approved, the price, just what you have in your car as of NOW.
If given enough data I will create some graphical depiction of my findings.
I'll start: Mobil 1 5w-30, Mobil 1 filter
*If you do not indicate a grade, I will assume 5w-30
MADBADGER is offline   Reply With Quote
Old 10-31-2013, 07:50 AM   #2
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Valvoline, AC Delco filter!
The Blue Ox is offline   Reply With Quote
Old 10-31-2013, 07:52 AM   #3
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
Royal purple 5-30w; .5 quart of Lucus oil stabilizer; ac delco filter(switching to k&n with my oil change in a few days)
13lstuner is offline   Reply With Quote
Old 10-31-2013, 07:55 AM   #4
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
Mobil 1 Extended Performance 5w-30 and purolator oil filter L12222
Sent from my SAMSUNG-SGH-I337 using Tapatalk
MrWray is offline   Reply With Quote
Old 10-31-2013, 08:04 AM   #5
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Same as you, OP!
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 10-31-2013, 08:06 AM   #6
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Caspers2SSRS is offline   Reply With Quote
Old 10-31-2013, 08:16 AM   #7
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Royal purple HPS 5w-30 , RP Filter
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 10-31-2013, 08:18 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
Old 10-31-2013, 08:19 AM   #9
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
The same as you OP, Mobil 1 w/ filter
Sikoriko is offline   Reply With Quote
Old 10-31-2013, 08:20 AM   #10
AztecCamaro
Drives: 2013 Camaro Dusk SS Auto Vert
Mobil 1 5w-30 and Wix
AztecCamaro is offline   Reply With Quote
Old 10-31-2013, 08:20 AM   #11
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
BTW, I do my own oil changes JACK!!, I also keep records as to when I do them.
Ir0nM4n is offline   Reply With Quote
Old 10-31-2013, 08:43 AM   #12
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Schaeffer Oil: #9003 Supreme 9000™ Full Synthetic SAE 5W-30
#9003 Supreme 9000™ Full Synthetic SAE 5W-30 is recommended for use in all gasoline fueled automobile and light duty truck engines including those that are turbocharged and supercharged. #9003 is API SN, Resource Conserving, ILSAC GF-5 and GM dexos-1™ Compliant.
TD Sheet:
WIX - Oil Filter
Part Number: 57060
And I change it myself!!!!
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 10-31-2013, 08:51 AM   #13
Slapshot
Slapshot's Avatar
Drives: 2010 2SS
Castrol Edge 5W-30
Wix Filter
Slapshot is offline   Reply With Quote
Old 10-31-2013, 08:53 AM   #14
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
Jalberdi99 is offline   Reply With Quote
