Old 06-12-2016, 08:39 AM   #575
Texzen
Texzen's Avatar
Drives: 2013 SW 2SS/RS/1LE
Oh man...not cool.
Texzen is offline   Reply With Quote
Old 06-12-2016, 10:43 AM   #576
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Originally Posted by Superman09 View Post
I can't win for losing. Last night my scout caught fire. Luckily I caught it quick enough before it did much damage let alone burning down my garage and quite possibly my house. All it did was burn up the feed line return line and what I think is a vent line.
Sent from my campfire using smoke signals
http://www.oreillyauto.com/site/c/se...0887/C0222.oap
This is happening more often than not. Because of the stuff they put in the gas. Rots anything rubber. I was replacing my fuel line once a year because of fuel rot. A couple of years ago I tried using a High Pressure fuel hose, you get at any auto parts stores. It has a small membrane for the I D, that does not break down with gasoline. I replaced all my fuel lines four years ago and they still look like new. It costs a little bit more than regular fuel line, but no more brittle fuel hoses.
Dimitrim is offline   Reply With Quote
Old 06-12-2016, 03:13 PM   #577
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
This is happening more often than not. Because of the stuff they put in the gas. Rots anything rubber. I was replacing my fuel line once a year because of fuel rot. A couple of years ago I tried using a High Pressure fuel hose, you get at any auto parts stores. It has a small membrane for the I D, that does not break down with gasoline. I replaced all my fuel lines four years ago and they still look like new. It costs a little bit more than regular fuel line, but no more tearing of fuel hoses.
Thanks, that's what I am going back with.
Superman09 is offline   Reply With Quote
Old 06-12-2016, 11:08 PM   #578
BlueStreakHouTX
BlueStreakHouTX's Avatar
Drives: 2012 Camaro 2SS RS IOM
Jeez, buddy, this is insane, here's hoping you catch a break. SOON!...
BlueStreakHouTX is offline   Reply With Quote
Old 06-13-2016, 11:46 AM   #579
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
Signed!
BTW, be careful taking the vehicle somewhere else for an evaluation that is not a certified GM shop. I had a car a few years ago that I paid to have a timing belt replaced on and the shop cross threaded the harmonic balancer bolt. After they repaired twice, new balancers and pulleys, the third time the crank was shot. Took it somewhere else for an evaluation before taking it to them the third time. Took written reports and pictures to court to explain their expert opinion that the first shop had cross threaded the balancer crank bolt. The shop's argument was that they felt the shop doing the evaluation had tampered with the crank trying to fix it and damaged it. They did not repair it, just evaluated it. Went to court and lost the case because I could not prove they had not tried to fix the car and in the end, cost me an engine from a salvage yard.
MyLocalDJ is offline   Reply With Quote
Old 06-15-2016, 07:19 PM   #580
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
He won't be getting pictures, I'm taking the real thing to his office when I go in and get all paperwork and documentation for the time they had my vehicle.
I hope you get it sorted...
Bad things sometimes happen to good people, but I believe that for all your suffering, SOMETHING has to start going your way as far as your vehicles. Hoping for some good fortune to come your way soon.
And for Sterling Auto Group?
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 06-15-2016, 07:54 PM   #581
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
I keep checking in on this thread hoping GM comes to their minds. Glad I'm not holding my breath. But I still hope it turns around
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
Cldgin2 is offline   Reply With Quote
Old 06-15-2016, 08:15 PM   #582
Superman09
Account SNAFU
Superman09's Avatar
It's currently got the oil pan off of it checking Rod bearings, which so far all seem to be good and tight.
Old 06-16-2016, 07:53 AM   #583
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Originally Posted by Camaro Dude View Post
....during the warranty period you mean, Right? Regarding last sentence...
Curious hea...What will you be doing after the warranty period ends? Keeping it for fifteen...twenty years say? Hmm? ��
Obviously, if you are trading in the lease after 4-5, disregard the question.
Ya during the warranty period i wont be installing one.
I dont see a reason not to install one after warranty is over.
I also dont see a problem with never installing one, and doing a manual clean every 40k miles depending how much you drive.
mikeSS is offline   Reply With Quote
Old 06-16-2016, 06:10 PM   #584
1bad1/le
Ed
1bad1/le's Avatar
Drives: 2015 camaro 1le 2ss
With forty something pages, I might have missed it, but has the Gm customer assistance people that watch this site ever comment or asked op to call them??
1bad1/le is offline   Reply With Quote
Old 06-16-2016, 08:24 PM   #585
Superman09
Account SNAFU
Superman09's Avatar
I had pretty much exhausted that route prior to making this post. But no they never posted.
Old 06-16-2016, 11:07 PM   #586
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I PM'd with them about it. This one was waaaayyyy over their heads.
Old 06-17-2016, 04:59 AM   #587
1lehunter
1lehunter's Avatar
Drives: 2013 1le 2ss rs black
What if you used your cars insurance comprehensive coverage ?
Had a car when I worked at a gm dealer that the costumer drove in a water hole sucked in the intake and hydro locked the engine.( put a big hole in the block, sunfire.)
That's what this costomer used to fix their car.
1lehunter is offline   Reply With Quote
Old 06-17-2016, 06:47 AM   #588
motorhead
Driving your car into a water hole and causing damage to the engine is an accident and a coverable issue just the same as if they would have done body damage. Getting in your car and starting it to fine no oil pressure is a part failure not an accident. That isn't an insurance companies problem. It shoukd have been GM's problem, but they used there own laweryer talk to escape their responsibility.
