05-22-2016, 03:39 PM | #491 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
So EVERYONE on CAMARO5 is a felon?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-22-2016, 03:54 PM | #492 |
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
05-22-2016, 04:37 PM | #493 |
Drives: 2015 SW 1LE BA NPP Recaros Join Date: Jan 2013
So i have a question then when my 1LE was ready for pick at the dealer the catch can was already installed by them.
05-22-2016, 05:34 PM | #494 |
2010RS/SS RUMBLEBEE
Drives: Drives a 2010 2SS/RS Camaro Join Date: Aug 2010
Everyone with a catch can is a Felon,this gotta be a Joke.
2010RS/SS RUMBLEBEE
05-23-2016, 12:19 AM | #495 | |
Drives: 2015 c7 Join Date: Nov 2009
FACT: PCV is a emission control device http://www.econofix.com/pcv.html FACT:change any part of any emission control device difference from OEM spec is federal crime. I how ever believe it might be ok to change to another certified system. Modding your PCV system is the same thing as deleting your cats. If you change any part of PCV you technically speaking have committed a federal crime, which usually for this results in a fine. The point i am trying to make is that this would be a easy case for GM because the OP has committed a federal crime. guys please just google what i am saying, its really not a hard concept to understand. If i was a lawyer it would be so easy to tell the court the OP has changed a finely tuned emission control device. When money is on the line, they will try everything they can to win the case. Last edited by mikeSS; 05-23-2016 at 12:29 AM. |
05-23-2016, 12:54 AM | #496 | |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
Further the EPA's policy states "This policy states that the EPA will not consider any modification to a certified configuration to be a violation of federal law if there is a reasonable basis that emissions are not adversely affected" which a my catch can does not adversely affect the emissions system, if anything it improves it. Sent from my campfire using smoke signals |
05-23-2016, 04:52 AM | #497 |
What GM includes on the 1LE is a clean side oil catching device. The catch can being discussed with this issue is the catch cans the car really needs. It is on the dirty side of PVC system.
05-23-2016, 04:55 AM | #498 | |
Drives: Love the one you're with Join Date: Sep 2009
If the catch can is an emissions certified componet and it was installed to manufacturer specs then there argument would be worthless. Regardless, they still would have to prove how it caused the oil pump to fail if that is what really happened to his car. I haven't read definitely that that was the failure. |
05-23-2016, 10:45 AM | #499 | |
Drives: 13 1LE Join Date: Jul 2013
The judge could fine the dude on a completely different citation, having absolutely nothing to do with the accused oil pump failure . So you are saying, by committing a federal crime, due to tampering with emissions control device, this thus renders your entire powertrain warranty void? This includes: Alternator, Oil pump, all actuators and electrical components internal to the engine (e.g., Active Fuel Management valve, lifter and oil manifold) cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, turbocharger, and superchargers....transmission, transaxle, rear diff, etc? If that is the case(which I doubt), then it's time for the manufacturers to re-write the rule book, and contract in a clean one liner, and end this once and for all. That would be a game changer for sure. Accusing the defendant with tampering with the emissions device, and breaking the law, and accusing the accused with hiding their head in the sand on faulty relief valves in the oil pump, causing catastrophic engine failure, may very well be two entirely different cases, as far as a judge may be concerned, that is our point here, well at least mine. |
05-23-2016, 12:35 PM | #500 | |
El Duderino
I bowl. Drive around. The occasional acid flashback.
05-23-2016, 02:25 PM | #501 |
Drives: 2010 Camaro Join Date: Nov 2009
Want to correct this statement, this is ONLY the case for the vented, breathers, or other cans/tanks that defeat the functions of the PCV system. ALL Elite Engineering systems are Emissions compliant and have zero negative effect on the PCV system and also reduce tail-pipe emissions. This again falls into what can and cannot legally void the warranty. So many "snake oil" varieties are being sold on EBay and from vendors that defeat or delete the PCV system and/or it's functions, and those DO give grounds to void as they reduce engine life and some cause engine damage over time as well as being illegal in all 50 States to use on the street. ONLY CA do we not have the CA specific CARB cert yet, but federally we comply by retaining a cloesd system that does not reduce any of the PCV systems functions, in fact ours enhance the factory PCV system if you get the E2-X dual valve or the E2 and utilize the dual outlets properly with the proper check valves.
05-23-2016, 05:01 PM | #502 |
Drives: 2012 White RS Convertible Join Date: Jun 2015
Signed. Good luck!
05-24-2016, 10:37 AM | #503 | |
Drives: 2022 2SS 1LE Join Date: May 2014
8/27:Ordered 2022 Vivid Orange Metallic 2SS1LE
11/09:Built 12/4:Took it home |
05-24-2016, 11:33 AM | #504 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
If you bothered to read the tag, it is only to be cut by the consumer ... Just saying
