Old 01-21-2014, 05:29 PM   #29
tones2SS
tones2SS's Avatar
Drives: '13 Roush S3 '16 Ram Sport 4X4
Originally Posted by jlugo View Post
Some of the 1st mods
LOVE IT!
tones2SS is offline   Reply With Quote
Old 01-22-2014, 08:09 AM   #30
gto406
Drives: 1972 GTO, 1969 Firebird
Originally Posted by brt3 View Post
STAGE ONE:
• Roll-bar or roll-cage
• Harness bar & harnesses
• Extra set of wheels/tires for street use
• Remove rear seat and install "parcel shelf" for hauling gear to track
STAGE TWO: [if I drive it and decide "I gotta fever and the only prescription is... more cowbell!!"]
• Katech engine mods
• Pfadt suspension mod
Perhaps go straight to the Z/28.R and skip these stages altogether?
...and then affix the Nurburgring sticker at the back!
gto406 is offline   Reply With Quote
Old 02-08-2014, 08:27 AM   #31
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
Mod number 1 ...... tow hook.
Mod number 2 ...... CCW wheels and tires for the track.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 02-08-2014, 05:58 PM   #32
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Originally Posted by 2SSRS@Gen5diy View Post
For me the first thing is better cold air intake headers intake manifold in a second set of rims for street tires.
The Z28 will come with short headers and how do we know if there is a Better CAI?
Only one I will do, that would be the Hurst shifter, they look better.
Skylane765 is offline   Reply With Quote
Old 02-08-2014, 10:33 PM   #33
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
We know let me say that, K and N is not the best out there.
2SSRS@Gen5diy is offline   Reply With Quote
Old 02-09-2014, 03:53 PM   #34
Skylane765
Skylane765's Avatar
Looking at it, looks like just the filter is K&N so the rest may be GM.
Old 02-10-2014, 09:22 AM   #35
Col. Brain
Drives: 2012 Ram 1980 Malibu
Originally Posted by SSTG View Post
Is this still a problem with the LS7?
I sold my C6 Z06 because of this issue being a possibility.
Trick Flow Gen X heads are on the way and will be buying a set ASAP
not sure if it is still an issue but Z06 owners were getting their engines replaced by GM
Kind of kills the numbers matching aspect though
But from my understanding - still the same problem exsists
Col. Brain is offline   Reply With Quote
Old 02-10-2014, 02:12 PM   #36
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Originally Posted by LOWDOWN View Post
A 2nd mortgage...
Don't know how I missed this the first time; nicely played, Sir!
brt3 is offline   Reply With Quote
Old 02-10-2014, 02:37 PM   #37
SSTG
Drives: 2014 Z51 Corvette
Thanks for the info. I'd love to have another Z. But not at the cost of a possible $15000 engine failure.
SSTG is offline   Reply With Quote
Old 02-13-2014, 01:19 PM   #38
yenkotown
yenkotown's Avatar
Drives: Hyundai 2.0T 10 former Corvettes
How about a lifetime pass to Bondurant high performance driver school......
yenkotown is offline   Reply With Quote
Old 02-17-2014, 10:22 PM   #39
brt3
brt3's Avatar
I'd appreciate input on the following mods for my incoming 2014. Again, I've not owned a Camaro before, so I fully acknowledge I'm not up to speed on all the details under the skin.
Here are the mods I want to make:
1. Lower driver's seat:
This is essential as I'm 6'7" and won't fit well with a helmet on. I'd really appreciate input from anyone as to whether or not the existing seat can be lowered. If not, I'll go with more of a racing shell. I'm assuming the Camaros have side airbags in the doors, not the seats -- can someone confirm that for me? I'm asking that because having them in the doors means no fault codes to worry about if I have to change the seats. Are there any other issues I need to be aware of?
2. Install harness bar & harnesses:
I'm really unaware of what's on the market that might be "plug & play" for this, or whether or not I'll need to have this fabricated.
3. Remove rear seat and install "parcel shelf":
I need this for hauling track gear and want to find a fabricator for this, as I'd like this to look as though it was planned all along by Al & Friends...
4. Order extra set of wheels/tires for street usage:
Any suggestions on street tires in the correct sizing? Lots of folks rave about the Michelin Pilot Sport PS2s, but they didn't work well on my last car. I suspect they didn't like the negative camber...
Old 02-17-2014, 10:36 PM   #40
Moreno1
Drives: G5.R
Hey Brt,
1. air bags are in the seats. if you go aftermarket, you will need to wire in a resistor to bypass the airbag light. lowering the factory seats will require chopping out the factory seat mounts which are spot welded to the frame, and gabbing up a new mount. We are running aftermarket seats with a cage, and even with the cobra's we are lowering them 1.5 inches to get the driver/pass head away from the cage.
2. there are options for this. Cipher is a sponsor here and sells them. Speedware also came up in a quick search.
3. some have done DIY seat deletes with carpeting to give it the factory look. We are thinking of producing a trunk/cab divider panel in carbon to give the interior a nice look.
4. michilin Pilot super sport are the michilin's 'next gen' ps2, and they have received rave reviews. there is also toyo proxes 1, which are fairly new, so not too many reviews on those. for wheels go forgeline hands down. I say they are the best, bar none, will shed 3-4 lbs per wheel compared to the OE 19's, and will make whatever size and offset you want.
can't wait to see your Z!
Moreno1 is offline   Reply With Quote
Old 02-17-2014, 11:50 PM   #41
brt3
brt3's Avatar
Originally Posted by Justin Moreno View Post
Hey Brt...can't wait to see your Z!
Justin -- thanks for the prompt response and great info! I appreciate you taking the time, as you seem to have your hands full with your present build. Which is a work of art, BTW...
molding a z/28, z/28
