Vararam
Old 01-01-2011, 10:13 AM   #1
Q8Y
Q8Y's Avatar
Drives: '12 F150
3.70 and 600rwhp
Happy new year.
Is it worth to install 3.70 gears on a supercharged SS producing 600whp??
We don't have a track here so no Track racing but I do some street racing and most of them from a roll still have the stock rims and wheels although planing to change them.I have LingenFelter 3.70 gears sitting here in the box wondering to do it or not.
Will the gears effect the car top speed??
P.S the supercharger it's a Novi 1500 so a Centri if anyone is wondering
Thanks
Ahmad
recieved 7-10-09 2010 camaro black 2ss/RS/6m
Q8Y is offline   Reply With Quote
Old 01-01-2011, 10:16 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Umm is be careful with street racing. And have you strengthened tieback end or axles at all? Id be worried about breaking something.
Click to view my build thread
Old 01-01-2011, 10:26 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You will lose a few MPH but only at the very top end. You will gain a noticeable improvement in acceleration through the entire RPM range. If your car is an M6 the change will not be as impressive as if you had gone with 4.10.
Old 01-01-2011, 10:28 AM   #4
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
You just don't need them...........
RBD is offline   Reply With Quote
Old 01-02-2011, 10:08 AM   #5
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I'm not sure if it will be worth it for the kind of racing you do. It sounds like you're into roll on racing and running high speeds (top end racing).
With 600+ hp the gears could make it difficult to hook up on the street (seeing you don't race on a prepped track).
SGOS252382 is offline   Reply With Quote
Old 01-02-2011, 12:26 PM   #6
Apex Motorsports
From a rolling start the torque increase would be a big advantage for getting the jump. If they do run out to max speed then it could hurt on the top end.
Old 01-02-2011, 12:37 PM   #7
SGOS252382
SGOS252382's Avatar
If he can hook up on the street with all that power. But from a roll, he should be ok.
Friday, when I was getting BMR Trailing arms installed on my Camaro, an old timer/racer at the shop tried to convince me to put 3:73 gears on my car . He almost had me sold. He said I'd definitely get in the 11s if I did.
I put gears in my 99 A4 z28. They definitely help get the car moving.
Old 01-02-2011, 12:44 PM   #8
Apex Motorsports
Friday, when I was getting BMR Trailing arms installed on my Camaro, an old timer/racer at the shop tried to convince me to put 3:73 gears on my car . He almost had me sold on getting some. I put gears in my 99 A4 z28. They definitely help get the car moving.
He would absolutely need to make sure he has the appropriate supporting mods. That is always the case. I tend to take for granted that people are consulting with a professional that is making sure they are not only building horsepower but taking steps to make sure it is safe and reliable. At 600HP he should have a pretty solid suspension set up.
In the L99 cars the 3.73s ROCK.
By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.73s you will realize an equivalent gain of approximately 15% or 61.5 rear wheel lb.-ft. of torque on a stock car. Since your car is modified it would be even greater improvement. The best part is that in these A6 cars you will only be at 2050 RPM at 70 MPH.
Old 01-02-2011, 04:14 PM   #9
Q8Y
Q8Y's Avatar
Drives: '12 F150
Thanks for the replies
The car is still WIP waiting for few parts to come but the aim to get to 600whp and was wondering to install the gears in one go or not since I have them here.
Everything else is stock the car is an M6.a friend of mine is getting me Pfadt spring and sway bar he is going to the States in a few weeks.
Thanks
Ahmad
11 Miles then off to Speed Inc. For 600rwhp Transformation talwell 5th Gen Camaro SS LS LT General Discussions 92 03-14-2012 10:15 PM
Cheapest way to 600rwhp Markushi Forced Induction - V8 24 07-25-2010 01:15 AM
Sooch bolts on 600rwhp!! SSOOCH 5th Gen Camaro SS LS LT General Discussions 47 03-02-2010 03:08 PM
LMR's Punisher Package makes 600rwhp Naturally Aspirated!! Late Model Racecraft Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 10-17-2009 01:35 AM
LMR's "Punisher 440ci" Package makes over 600rwhp NA in corvette Late Model Racecraft Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 09-02-2009 05:38 PM
