10-09-2017, 08:24 AM | #29 | |
DaWolfOfAllStreets
Drives: 17 C Coupe, 17 1LE, 16 Scion iA Join Date: Jun 2017
10-09-2017, 10:56 AM | #30 |
he LT4 in the Zl1/Z06 was designed for road course use and deal with sustained high rpm and the heat from the 1.7 liter supercharger which is probably why GM went with Forged slugs. That does not mean you can not get good results and longevity from the LT1 with boost by using more efficient blowers and chemical cooling to keep the pistons happy. The bottom line is there are guys on this board pushing into the 650whp territory on SBE LT1's and making low 10 and 9 second drag strip passes with no issues. will the engine last 100k miles doing that, I doubt it but I don't think anybody expects a engine to last that long making that kind of power. You guys act like a engine component is fragile if it can only handle 720 fwhp. That is still a lot of power for factory components. We have become spoiled in this day in age on how easy it is to make HP. Now if it was only that easy to put it to the ground without breaking parts.
I do question why GM would limit the HP potential of the LT1 by choosing a piston and ring pack that limits HP production to roughly 720 fly wheel, when the crank/rods can safely handle more. I am sure others think the same thing including Swagger...Perhaps it's because they felt no need to put a 900hp capable piston and ring pack in a engine that's fuel system is limited to 650hp? I do know this has been a ongoing thing with GM going back 20years. GM has always used hyper aluminum slugs, and the crank and rods have always been more capable even in the LS stuff. However guys still make big power on SBE LS3's with FI. The fuel system upgrades are much less expensive of the LS stuff though.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 10-09-2017 at 11:30 AM. |
10-09-2017, 06:00 PM | #31 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
10-09-2017, 09:06 PM | #32 |
I don't think anything I said was "Off". The C6Z was a 11:1 compression port fuel injection engine. Big difference from DI far as piston cooling...
LS1/6 LS2/3 all have handled boost just fine upwards of 12psi and pushing over 600whp. They use hyper pistons...it's all in the tune.
2016 NFG 1SS A8
10-10-2017, 01:39 AM | #33 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
plus a full warranty...
OP, if taking a trade in hit is an issue, will u have sufficient funds for a new motor just in case the modded one goes "boom"? And as we all know ANY motor can go "boom", stock or otherwise. |
10-10-2017, 05:17 AM | #34 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
I would disagree with the statement that the rings on the stock piston are fragile. They are fine...just have a very small gap that can cause issues with boost. But only with lots of it for a sustained time. This was explained by 'Pro Charger dude.
10-10-2017, 08:20 AM | #35 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
If i didnt buy a 1LE already then way I wouldn’t even ask this question and just get the ZL1 problem is I already have the 1LE so the car isnt 43K anymore... went to car max... my car is in mint condition and just like RPproductions i got an 33K offer.... im not willing to let go of 10K just because... so technically im putting 25K towards the ZL1 not 15K
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
10-10-2017, 08:30 AM | #36 |
@Blackmamba_1LE
I do but I really dont think it would happen (knock on wood) i really dont want more than 650... at 600 on the dot is more than content... its my daily driver plus i got to mexico alot and roadcourse will be visited more frequently
10-10-2017, 08:33 AM | #37 | |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
I'm running 9PSI at 6500 RPM, but I'm at 6200 feet altitude, so pretty safe (my uncorrected HP is 475ish to the wheels). I'd go with the same (small) blower being down near sea level, but with the stock pulley and no more than 7PSI. I'm happy with my Vortech for sure, sounds great, not a lot of gear lash from the head unit etc. it's nice. and Yes, stay at 600 uncorrected (which at your altitude, will also be corrected) HP to the wheels where you are at...that is more than plenty fun IMO. And you'll roast 99.8% of vehicles out there with that.
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
10-11-2017, 01:13 PM | #38 | ||
Drives: 2017 1SS 1LE Join Date: Apr 2013
10-12-2017, 02:49 PM | #39 |
Drives: None Join Date: Nov 2013
