Old 02-21-2013, 12:45 PM   #1
HubStep
HubStep's Avatar
Drives: 2010 Victory Red 2SS
So what happened to the rumors about GM's 8 speed double-clutch? Coming in 2015?
So we all read the rumors pre-announcement:
http://www.lsxtv.com/news/c7-corvett...-8-speed-auto/
"According to Motor Trend, GM has found itself in a bit of a bind regarding its next-generation transmissions for the upcoming 2014 C7 Corvette, among other vehicles. Their own in-house unit isn’t quite ready yet, so the General has outsourced the work to Aisin, a company owned in part by Toyota. It appears this delay only affects the automatic transmission, as other rumors indicate that GM has outsourced the 7-speed manual transmission to ZF.
Aisin makes two eight-speed automatic transmissions, including one capable of handling high torque loads for cars like the upcoming Corvette. More importantly though, GM needs to offer a smooth and efficient eight-speed automatic for its Cadillac brand. Other automakers like Mercedes and Chrysler already offer eight-speed automatics, so GM really needs to offer the same just to stay competitive."
I was pretty surprised when they announced a 6 speed auto to be honest... which leaves us in an interesting situation. Think we'll see the 8 on the 2015, or will they hold out for the Z06 and ZR1 models?
Oh, and hello from Camaro5
HubStep is offline   Reply With Quote
Old 02-21-2013, 12:59 PM   #2
Stingray
just can't get enough
Stingray's Avatar
I think it's a good possibility that an Auto box w/ greater than 6 forward gears will be on a future C7... if not '15 then soon after that. It's always about incremental or selective upgrades and improvements model year after model year.
Old 02-21-2013, 01:04 PM   #3
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
So, since Mercedes and Chrysler offer them, Chevrolet/GM must also offer an eight-speed transmission?
How is that logical?
First answer why a vehicle would need 8 forward speeds and then you'll understand why it's not an absolute necessity for the Corvette.
Eight-speed transmissions were developed to reduce road noise in high-end vehicles by keeping gearing within their engine's narrow power band that creates the most power without making excessive noise.
First off, the Corvette has a really wide power range, so you can put down the majority of the power without needing to shift repeatedly. And secondly, I'm pretty certain that Corvette drivers want to hear the engine as they stomp on the go-pedal.
So again, why does Chevrolet/GM ned to offer an 8-speed in the Corvette?
My VIN = 2G1FK1EJ9A9105017
Old 02-21-2013, 01:07 PM   #4
HubStep
HubStep's Avatar
TBH I'm more excited about the double-clutch than the 8 speeds. I know more isn't always better, but it's documented GM is working on it so they must see some value in it.
Old 02-21-2013, 02:27 PM   #5
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Here's an earlier post on why GM went with the 6 speed auto:
Originally Posted by Tran View Post
Some interesting bits:
He explains why the choice to go with a 6 speed automatic transmission (and not 8 speed) - see 10:30 into video. Basically reason is that the 6 speed is good for high torque engine like the LT1, while fitting an 8 speed just adds weight and mass.
Also says that they haven't shared everything about the car yet (woohoo!).
Tran is offline   Reply With Quote
Old 02-21-2013, 03:23 PM   #6
Drives: 2023 GMC Canyon, 2020 Colorado
8 speed transmission's on the way but trucks will probably get it first.
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 02-21-2013, 04:07 PM   #7
The_Blur
Moderator
The_Blur's Avatar
I'm not sure I understand the benefit of that many gears.
Old 02-21-2013, 04:48 PM   #8
CamaroSkooter
The purpose of multiple gears is to keep the engine at an rpm that is in the most efficient part of the torque curve.
If your engine is high revving then the torque curve is probably really narrow and you'll need to shift gears more times to keep it in that range.
Old 02-21-2013, 05:33 PM   #9
mikeyg36
Drives: 2015 Z/28 #533
I really wish they gave it a dual clutch. Just as a reminder, the C6 used a 4 Speed auto for the first year or two.
Old 02-21-2013, 05:53 PM   #10
volsfan0911
Drives: '10 GTI for now
It sounds like the 'Vette is torquey enough that it could do nicely with 3-4 gears for the LT-1. However, the increased number of gears would be more for fuel economy in the C7 application. Tadge's interview at the reveal has him saying a couple of interesting things - 1) they looked at an 8 speed auto but it wouldn't fit (Aisin or ZF sourced probably) and 2) that a DCT was considered but there wasn't an available unit which could handle the torque. He goes on to say that 6 gears is fine for the auto. Yet they added a 7th (3rd overdrive) on the manual
volsfan0911 is offline   Reply With Quote
Old 02-21-2013, 05:54 PM   #11
volsfan0911
could be a similar scenario here where the 8 speed isn't ready so they're going with the carryover box for the first year. Seems to be a popular theory on corvetteforum and, obviously, there's a precedent for it as well with the Vette now.
Old 02-21-2013, 06:04 PM   #12
Stingray
Stingray's Avatar
Exactly what I iterated earlier... in 2 models years or so, I think we may see A/T improvements whether dual-clutch, 8-spds, etc... I would think that Chevy's flagship will have to keep up with the Jones'es just because of competition or keeping up with the times even if it isn't absolutely required.
Old 02-21-2013, 06:07 PM   #13
mikeyg36
agreed
Old 02-21-2013, 07:32 PM   #14
HubStep
HubStep's Avatar
A dual-clutch automatic would likely smoke the manual, shaving a decent bit off the 0-60 time.
