Roto-Fab
Old 02-14-2021, 07:58 PM   #1
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
Spun bearing
Apparently a common issue in the LSA world. But it’s part of the game I guess. Currently sitting at 703 whp. bolt on +e85 car. No cam, heads or internal work. Hopefully I can salvage block. I’m sure crank and bearings of course will need to be replaced. Any suggestions on upgraded bearings? Buddy of mine uses “king” brand bearings I believe. If block, crank and bearing are all trash. I’ll prob be in the market for a new short block or stroker. Any advice is welcomed!
I’ll be letting an engine shop put it all back together. And I’ll throw motor back in. I’ll also be upgrading to the melling 10355 HV oil pump, SS3 GPI cam while it’s out. I was using 5w30 oil at the time of it spinning. I’ll be upgrading to 20-50 VR1 oil as well. Once motor is back in the car. Will I need HV oil pump if I switch to VR1? I got a few LSA buddies running factory pumps with 850+ . Any other suggestions?
787WHP/ 719TQ | Fully Forged Short Block | Custom Spec GPI Cam | DSX aux pump & FF sensor| 1200cc FIC Injectors | Lingfelter 10.0” pulley & ATI damper | RotoFab Intake | ZZ Performance solid isolator | Kooks Headers | Corsa Catback | AFCO dual fan HX | Reinforced IC brick | AEM 3-in-1 Gauge | GPI Tuned | Carbon Fiber WickerBill | Morimoto Tail-lights | WELD S71 + ET STREET R’s
Astatenate is offline   Reply With Quote
Old 02-14-2021, 08:23 PM   #2
Triple5even813
Learner of things
Drives: 2013 ZL1 M6 coupe, black
Dang, that sucks! You'll be back stronger than ever though! Mine is making quite a bit more power than that on the stock oil pump and stock bottom end, and the oil pressure is holding steady at 30psi hot with Mobil 1 5w30... But who knows for how long?
Triple5even813 is offline   Reply With Quote
Old 02-14-2021, 08:25 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Ughhh... hate to see this but hopefully you caught it quick.
Old 02-14-2021, 08:53 PM   #4
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
How did you catch it? Low oil pressure? Just want to know what to look for.
rednecks70 is offline   Reply With Quote
Old 02-14-2021, 09:32 PM   #5
hammdo
'It's an experiment'
hammdo's Avatar
My LSA build worked out great! GPI and I discussed it and I’m beyond pleased. Talk to Aaron — he’ll help you spec a good one...
-Don
747 RWHP 794 RWTQ
Old 02-17-2021, 11:09 PM   #6
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
Yeah I was debating upgrading. I figured for $200 why not get a Melling 10355 HV that supposedly put around 10-20psi more oil pressure out. I think it will help with the thicker oil 20w50 VR1 everyone has been telling me to run.
Fingers crossed. Part of the game tho. Luckily I got a daily to drive. And it’s winter when it broke. Not mid summer. Looking for the bright side lol
Did a very small pull to pass someone. And just happened to look at my oil temp gauge and it was at like 240° on a cold night. Then looked at oil press and it was sitting at like 10-15 psi cruising. And only like 6-8 psi at idle and heard it lightly knocking. Luckily I was 1/4 mile from my house. Got it on my street and shut it off. Coasted into my garage. Where it’s been the last couple weeks. Til I can pull motor.
-Don
Yeah GPI is literally 2 miles from my house. I been in touch with Ryan & Ben. I’ve had people tell me it could be a number of things (in the tune, too much dome pressure, or failing oil pump, the fact I was using 5w30 M1 with my power level, just normal LSA issues, and blocked pickup tube) guess we will find out.
Old 02-18-2021, 10:45 AM   #7
RyangAsh
Drives: 2014 ZL1
Brah, these motors are not at all spec'd for 20-50w........ might want to do some studying on clearances before "listening to everyone". The hotrod world is pretty sad these days. No one wants to learn..and if they do they do it the hard way several times.
One of the best tech sites in the world is dead as ****. LS1tech...there was infinite info and data there. Maybe a good place to start reading.
RyangAsh is offline   Reply With Quote
Old 02-18-2021, 10:54 AM   #8
BLK95-Z
BLK95-Z's Avatar
Drives: 2010 Camaro 2SS
The factory oil pans aren't the greatest for hard acceleration. We suspect it as being a factor in our last failure.
2010 Camaro 2SS - Built by Fast Track Performance
427 lsx - callies billet ccw - oliver rods - wiseco pistons - BTR cam - 1/2" studs - TFS 245's - Holley hi-ram
Custom twin turbo kit w/billet Precision 7675's - PW46 wastegate's - JGS bov's - 6" thick intercooler
RPM freshened Rossler billet th400 - 2.10 gearset - PTC converter
ZL1 diff & axles - Driveshaft shop aluminum DS
Injector Dynamics 2000cc - cable drive pump - e85 fuel
Weld v-series 17x4.5 front - 15x10 w/MT et street 315/60-15
Stock ecu & all factory options retained
1288 rwhp - 2016 LS Fest dyno challenge winner
8.97 @ 159
BLK95-Z is offline   Reply With Quote
Old 02-18-2021, 04:06 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Man, that just sucks. Sorry to hear it! Hopefully it's not too much carnage and most stuff will be salvageable with any luck. In any case, good excuse to build it back stronger.
Best wishes, dude!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 02-18-2021, 04:49 PM   #10
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I was just watching a video of a guy explaining how ls blocks should have a larger oil pan especially with a higher volume oil pump.
Bigdumogre is offline   Reply With Quote
Old 02-19-2021, 01:53 PM   #11
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
Man that’s crazy. Every LSA guy Z or V around here is running that 20w50 VR1 and I was the only one running 5w30 and I somehow spun a bearing. Both my tuners at GPI recommended the VR1 as well. As it’s not daily driven. I guess I’ll do some more research.
Yeah I could see that. Do we have an aftermarket option that would work well? Haven’t done much research on the pan.
Best wishes, dude!
Yeah for sure. Upgrading bearings and oil pump, with big cam for sure while it’s out. I don’t have the power goal of 1,xxx so I think I’ll be fine just with OE parts (crank, etc) if destroyed. But we shall see.
Care to explain why? I never really understood pan volume in comparison to a HV oil pump. If the pump is flowing more sufficiently then what’s the need for a bigger pan? Just curious.
Old 02-19-2021, 07:13 PM   #12
Shodown
Shodown's Avatar
Drives: 2014 ZL1
I've heard of guys cracking the block going over 1000 hp, supercharger rattle, burned up piston from too much boost, collapsed bricks and rocker/trunion issues but this is the first spun bearing I've read about. I wouldnt say it's common. Lots of guys run 5w-30 with zero issues so I'm wondering if you had a one-off bad oil pump or something.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 02-19-2021, 07:38 PM   #13
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
Care to explain why? I never really understood pan volume in comparison to a HV oil pump. If the pump is flowing more sufficiently then what’s the need for a bigger pan? Just curious.[/QUOTE]
It's not about the pump. More about returning oil to the pan. Gravity can only do so much. There's also a difference between high pressure and high volume pumps.You need to ensure that theres enough oil in the pan to pump baseed onthe flow from the pump and return to the pan.
During higher RPM operation theres lots of oil up top from pumping and windage.
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 02-20-2021, 12:00 AM   #14
Astatenate
Astatenate's Avatar
Drives: 2015 ZL1
It’s apparently very common in the LSA world on the V side. There’s so many posts about spun bearings. It’s not even funny. I reinforced brick. Did solid isolator. Vented crankcase. I did everything I thought would be good enough. I read horror stories about M1 5w30 which is what I was told to run. Now all my racing buddies and tuner are telling me I shoulda been running VR1 5-20. So idk. I trust their word. And yeah I can’t wait to get it out and see the damage.
