Old 05-08-2020, 05:01 PM   #1
evonschu
evonschu's Avatar
Drives: Camaro ZL1
Question PSS or PS4S tires
Need to replace the tires on my 2013 ZL1. I have Michelin 315/35/R20 and 295/35/R20 PSS on there now. Weighing in on if I should get these again or opt for the newer PS4S tires. Difference being that it'd be 305/35/R20 and 285/35/R20's for the PS4S. Not sure if losing the extra 10mm in width of the rear tires but having a better/newer tire would be beneficial over the PSS's I got now in 315's. Any input greatly appreciated. Thanks.
2013 Camaro ZL1 M6: Rotofab CAI, JDP ZL-R Rough Idle Cam, Upgraded Valve Springs and Pushrods, Ron Davis Heat Exchanger, Alky Methanol Injection, Rx Catch Can, 87mm VMAX Ported TB, Summit Performance Spark Plug Wires, 10" Lower Pulley, Kooks 1 7/8" Headers with Magnaflow Cats, ID850 Injectors, Johnson 2110R lifters, EBC Slotted Rotors+Hawk Pads, Rotofab SC Coolant Reservoir, 160* Thermostat, Custom Mild to Wild switch, Tune, 1st to 4th bypass. 685 RWHP / 640 RWTQ.
evonschu is offline   Reply With Quote
Old 05-09-2020, 09:54 AM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I've never had the PSS, but I feel like compound technology is still advancing, so I went with the 4S. My mod list is very similar to yours and I think it's a great tire. Hooks all the way through 2nd gear when warm enough, and very good in aggressive street cornering.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 05-09-2020, 11:49 AM   #3
DannyZ
Drives: 2014 ZL1
I just had a set of the 4S's spooned on last week. I haven't really wailed on them yet, as they are still new but I noticed they are indeed quieter and not as harsh riding as the stock Goodrock's they replaced.
And they must be pretty popular; my guy had to go to three places to get four tires.
DannyZ is offline   Reply With Quote
Old 05-09-2020, 05:47 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I wouldn't get the MPSS. Not anything to do with performance but that tire hasnt been around for like 3 or 4 years so if you run across some, they are going to be old and not likely to last as long as desired....... OR you could run into the problem my other half had and have the MPSS dry rot within a year because the tire was already 3 years old
Just get the 4S. I've had both and the differences you cant even tell unless you're at the tires limit.
CamaroDreams76 is offline   Reply With Quote
Old 05-09-2020, 06:31 PM   #5
Coop[580
Coop[580's Avatar
Drives: 2012 ZL1 Ashen Grey
I’m looking into the PS4s for my front tires. Probably a 295/30/20. I have R888Rs for rears. The stock GY are garbage
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam
Tuned and built by Speed Inc
635/632-93 octane
725/738-E85
Coop[580 is offline   Reply With Quote
Old 05-10-2020, 12:04 PM   #6
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Get the PS4's since they're replacing the older PSS tire. I have them and love them. Quiet, smooth and still have great traction straight line and in the twisties.
DrkPhx is offline   Reply With Quote
Old 05-11-2020, 11:50 AM   #7
evonschu
evonschu's Avatar
Drives: Camaro ZL1
This is all good advice, but no one has addressed if the size change from MPSS in 315s to MPS4S's in 305s is going to create a loss of grip, however slight. Anyone go specifically from 315's in MPSS to 305's in MPS4S's that can share their experiences?
Old 05-11-2020, 01:07 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I just switched from MPSS to the 4S on my car.
You will not lose noticeable grip going down 10mm on the rears. You will gain LOTS of traction on cooler days. I noticed the Super Sports liked to be 80 degree days or better, but the 4Ss are just fine at 50+.
Switch to the 4Ss and don't look back.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 05-11-2020, 01:18 PM   #9
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Let me know bud, I am about to go down that pat as well.
owhite3003 is offline   Reply With Quote
