Old 02-16-2019, 01:16 PM   #6539
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Did a little DIY TSB.
Gunkk is offline   Reply With Quote
Old 02-16-2019, 01:48 PM   #6540
Soleil
Soleil's Avatar
Drives: Camaro 50th anniversary edition
Is that the cable rubbing issue in the engine compartment on the passanger side close to the fuse box?
Soleil
_____________________________________________
A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl)
Soleil is offline   Reply With Quote
Old 02-16-2019, 02:42 PM   #6541
Gunkk
Gunkk's Avatar
Exactly. My cable had no rub thru yet on the outer fabric wrap, so I added a piece of 3/4” wire loom and a zip tie.
Easy peasy.
Old 02-16-2019, 05:47 PM   #6542
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Way easier to put protection on the metallic part of the car...
Small pipe cut on the length covering the sharp metal piece ;-)
Biscuit.fr is offline   Reply With Quote
Old 02-16-2019, 06:36 PM   #6543
Gunkk
Gunkk's Avatar
Yeah some door edge protector would probably help too, but I happened to have the wire loom and zip tie on hand.
File Type: pdf zl1 harness repair tsb N182167990 18258 (3).pdf (688.4 KB, 310 views)
Old 02-16-2019, 10:47 PM   #6544
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Charged the battery, roads are gross so it's sitting. Thinking of taking mine to look at the Jacked Up Camaro(Blazer, they look great!), Premier's are already marked down $2500 nearby. Maybe they will hit the 8k off the Acadia's are by fall.
And some perspective for all of us grousing about our 8 speed's, Honda recalled the Ridgeline because car wash soap can corrode the Fuel pump. Now that's a FAIL(and I AM a Honda owner.) I thought sub par transmission fluid was bad, an important component that can't hold up to being washed
"Why is your car on fire?"
"Because I washed it" Can't make this stuff up.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 02-17-2019, 02:49 AM   #6545
441bertre
441bertre's Avatar
Drives: 1998 SS, 2018 1LE
Today's garage report...
Started off today installing some of the items I've collected over the winter. First off was the ZL1Addons rock-guards. I was skeptical at first about getting the rock guards thinking they might have a mudflap look, but after getting the car in the air and taking a closer look at some of the paint I can't believe at 700mi I already have rock chips. Glad I got them on!
Next up was the front license plate bracket. Sometimes law enforcement in MD can be sticklers for front tags so I'm glad ZL1Addons had this solution without having to rivet the front bracket to the bumper. I don't have their tow hook so I chose the option when ordering but ended up not needing it to install the bracket so I'm not sure the reasoning.
AND finally we started the Adam's Polishes Ceramic Wheel Coating! I've detailed plenty of cars in my day but this is the first time I've applied one of these ceramic coatings. We watched the Adam's video on-line to get a little guidance and then we were underway. Started out giving them a good scrub down with the Adam's Wheel Cleaner and then let them dry. Adam's then says you prep the surface with the coating prep and wipe away. After that you start laying the coating. At first we were following along like the recommended letting it sit for 30sec and then wiping away after but then we noticed it wasn't getting tacky like the video said so we started waiting 1-2min and then wiping way. Still trying to perfect the process with the coatings, tomorrow I'll hit it was the ceramic boost and hope it did something!
So far the finish product!
1998 Chevrolet Camaro SS
2018 Chevrolet Camaro SS 1LE
441bertre is offline   Reply With Quote
Old 02-19-2019, 02:38 PM   #6546
TBAtilidk
Drives: '16 Camaro 2SS 6M HBM
Not today but this past Saturday I bought it if that counts. 16 2SS 6SP
TBAtilidk is offline   Reply With Quote
Old 02-19-2019, 02:42 PM   #6547
majik755
majik755's Avatar
Drives: 2017 Camaro RS Fiftieth Anniversary
Of course that Counts! Best thing you can do to a Camaro is bring it home!
majik755 is offline   Reply With Quote
Old 02-19-2019, 02:47 PM   #6548
lowrred
Drives: 16ss, Ram, r32
busted it up
lowrred is offline   Reply With Quote
Old 02-19-2019, 06:54 PM   #6549
tlk-1997
tlk-1997's Avatar
Drives: 1997 Camaro SS LT4
I installed SS emblems on the doors. Installed custom made fuse plate. Installed custom made pedal inserts. The pedal inserts and fuse plate are made by Camaro6 members.
2018 Camaro 2SS M6 Hot Wheels,Edelbrock 2650, Hurst Short Throw Shifter. Production Number 90
1997 Camaro SS M6 LT4 tribute
tlk-1997 is offline   Reply With Quote
Old 02-20-2019, 09:40 AM   #6550
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
This morning before work. I hate this shit.
It’s supposed to turn 45 and raining tonight and the rest of the week and the rest of the week though thank god.
ItsChristianInHD is offline   Reply With Quote
Old 02-20-2019, 09:48 AM   #6551
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
I lived in NY for 47 years. I sure don't miss that.
Previously Owned:
2018 Silver Ice Metallic Camaro R/S
1992 Dark Teal Camaro R/S 305 V8
SSShark is offline   Reply With Quote
Old 02-20-2019, 09:49 AM   #6552
ItsChristianInHD
That’s why I’m packing my bags in January haha. I’m out.
