View Poll Results: What should we ask Al in January? | |||
Explanation of Launch Control | 252 | 61.02% | |
A8 Transmission Shudder Question | 134 | 32.45% | |
ZL1 1LE Nurburgring Suspension Settings | 17 | 4.12% | |
Why Was The M7 Transmission Not Used | 10 | 2.42% | |
Voters: 413. You may not vote on this poll |
Thread Tools |
01-19-2018, 10:25 PM | #57 |
CamaroFans.com
Hmmmm now you really have me wondering. Can you repeat that 3.7?
01-19-2018, 10:48 PM | #58 |
Drives: '17 ZL1 Join Date: Jul 2016
That is interesting. I'm sure the convertibles run a slightly different software baseline, so there could be something there, but I believe there have been some guys with the convertible ZL1 who have experienced the "bogging" problem. I don't recall the transmissions for these cases though.
I'm a bit of a skeptic by nature, so I can't help but think that under more controlled circumstances, such as a drag strip, your experience would be similar to the rest of us. I've actually noticed myself that high-traction surfaces are slightly more problematic for "bogging", which makes sense if it's because it's reaching torque limits in the software. Anyway, just to be clear, I don't have any data that ties to the eLSD specifically. I thought the eLSD was related originally, but I really can't think of a reason why the eLSD would matter unless it's just something coincidental. The nuances with the wheel slip % and the conservative torque management are my two primary suspects. One area I haven't looked into much is the Performance Traction Management (PTM). There could be a tie in there, but I simply don't have a way to capture the data to be sure. I suspect PTM needs to know exactly how much grip is available in order to work. To know how much grip there is, GM must be letting the wheels slip a little on purpose (and then pulling power to regain grip). I don't know how much PTM is integrated into the launching of the car, but it seems plausible that there could be a relationship there. The good news is, the poll is looking promising for this question. I've been making educated guesses for about 8 months now with no way to validate the theories. I'm really looking forward to knowing what's actually happening.
01-20-2018, 12:26 AM | #59 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
I can’t count how many videos I’ve seen of stock a10s leaving hard(ish) with zero bog. I’ve never noticed bog in my a10 although admittedly never really focused on max effort launches from a dig.
And I don’t think I’ve EVER seen a video of a stock m6 leave hard, without bog. Hard for me to think both platforms suffer from the same issue. We know they both have TM.....but not anywhere near the same amount IMO. |
01-20-2018, 06:52 AM | #60 |
Drives: '18 1SS 1LE Join Date: Sep 2017
In an automatic, the driveline is loaded whenever the car is in gear then accelerated. Pressure is already applied to the entire driveline, and then increased quickly.
In a manual the entire driveline is slack until the clutch is released. You go from zero load, to work, all at once. All the lash in the diff is taken up, all the lash in the trans is taken up, the driveshaft is loaded and power is applied. The abrupt application of power in the manual versus the smoother "softer" application in the automatic may be why the same potential issue seems different and worse with the manual ZL1. A combination of torque management and traction control/Elsd programming. I've never experienced this in these cars, just my thoughts from what I've seen posted. |
01-20-2018, 08:24 AM | #61 |
IMO the M6 Bog and A8 shudder should both be asked with all the activity they are getting. One gets asked this month and the loser gets asked next month. Then everyone is happy.
01-20-2018, 08:56 AM | #62 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I agree.
Best 1/4 Mile: 12.24 @ 115.9 mph |
01-20-2018, 09:48 AM | #63 |
Bring It
I'm kinda nervous about the answer already.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
01-20-2018, 10:09 AM | #64 | |
CamaroFans.com
Also, TM and Bog... are we using these terms interchangeably? |
01-20-2018, 11:39 AM | #65 |
01-20-2018, 11:47 AM | #66 | |
01-20-2018, 12:30 PM | #67 |
CamaroFans.com
That's true and I've been side by side with them. A lot is the driver as well, but overall the M6 is virtually impossible.
01-21-2018, 01:22 PM | #68 |
Thank you Al Oppenheiser!
01-21-2018, 02:41 PM | #69 | |
Drives: Duramax Join Date: May 2017
Does anyone thing the Factory Loaded Tune Parameters are the same in both the A10 and M6? You can get away with a "Soft Launch" with an Auto but not with the steep gearing of the M6. Just a Sunday with Beer and the Internet........ Btw, I haven't been able to log into a ZL1 to do a Data Dump. |
01-22-2018, 08:42 AM | #70 |
Drives: 2018 ZL1 Black M6 PDR Join Date: May 2017
A8 caught up in one day on votes? That's not good.
