01-04-2022, 03:46 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Brakes
I had my brakes replaced at all four corners, three years and 52,000 miles ago with Power Stop drilled & slotted rotors and their "Z-something" pads. Yesterday I took the car in because the rears were making noise and starting to grind, just like they did when I had my brakes done three years ago.
So basically, I had the rears done, but the fronts are still at 5mm (which is 50% life left). I'm an "Old fart with a young car," So I'm used to the front's doing 80% + of the braking and wearing out twice as fast as the rears. This "reverse of normal" is still strange to me. At least (it appears anyway) that the rear brakes still control the height of the brake pedal since the new pads & rotors were installed yesterday, I can tell a difference in the height of the pedal as well as a better "feel" to it when depressing the brakes. Just a few odd thoughts at quarter of five in the morning.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
01-04-2022, 06:14 AM | #2 |
i have a couple of questions for you then.how many miles did you get out of the original pads and rotors? do you consider the power stop pads and rotors to be equivalent of OEM?i have 72,000 miles on my car and currently running the original pads and rotors,im wondering how long they will last.
01-04-2022, 03:18 PM | #3 |
I had new front pads and rotors at 78K miles. They had plenty of life on them, I just changed for a front end vibration. I've never touched the rear but they looked good to me. SS owners might have a different story.
01-04-2022, 03:38 PM | #4 | |
Camaro #4
The rears ran me $556 out the door yesterday, which I didn't feel was bad for brakes that lasted 3 years ~51,000 miles.
Don M
01-04-2022, 04:45 PM | #5 |
376 cubic inches of fun
With about 80,000 miles on my car, the gap to the wear indicators is about the same front and rear. However, it's an SS with mono block calipers front and rear, plus I don't drive it during salt season.
In cars that have floating calipers, like yours, I have experienced early rear brake wear. The rear brakes are more vulnerable to salt spray and corrosion, resulting in dragging and premature pad wear. When you had your last brake job, were the calipers rebuilt or replaced, or even cleaned and lubed? |
01-04-2022, 09:32 PM | #6 | |
Camaro #4
Don M
01-06-2022, 05:21 PM | #7 | |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
And damn straight on the stopping power, I tell people I can late brake a corner and sling the bugs off the front bumper! |
01-07-2022, 02:52 PM | #8 |
Drives: 2013 ZL1 Join Date: Nov 2018
Activating traction controls eats rear brake pads like a fat kid at a buffet
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
