Old 12-15-2011, 11:09 PM   #1
Moreno1
Drives: G5.R
Project Cleaning the Clutter in Our Engine Bay
Hey guys, I thought it be fun if we had a place to share ideas on what we can do to clean up our engine compartments so that they don't look so much like a plumbers convention. I look forward to everybody's input and contribution.
Contributing members gallery:
G5.R
IMdyinhere
Cz2815
KingofBattle
Sickness91Z28
BiggFoot
kjkjr27
2012InfernoSS
SS4PK
Calbert1999
OVRKILL
greenmachinedriver
Synner
67motorcat
572HP
aquablueL99
BIGDADDYGENE
BLACK10
bmbbl be
brooks35
cpoboats
CUPRA
donalddb
EZSPEED
Farthestnorth
GlennP
INDY
Kilo-9
LS2SLOW
MRGOODWRENCH3
NC-V aka Kyle
Another great project from NC-V aka Kyle
PAULSS
platinumss
Rcfiddy1
robsls3
Roctrux
rtcat600man
Switchback700
Pharmaro
Farthestnorth
My 5th:
Copper98
ss/rs-matt
TXM62SS
tys2010camaro
Pyroboy
ChitownSS
Gene
Dekan513
The Stig
Powhusku
Anybody that wants to get added to the list, let us know.
Thanks guys for all the help and inspiration! Now lets get more names on the list.
If anybody has an better pic they like me to replace with the ones I have, PM me the picture.
Anybody who has pics of their engine bay they'd like me to post, please post them and I will keep updating the list.
Pictures and link references have been added for faster browsing:
Powder coated intake: 479 510
New front drive: 767
Recreating upper radiator hose:
445
Removing all the casting (both inside and out), deburing and media blasting the block:
1245 1220 1177
Tucking and Reworking Wire harness:
Reworking wiring harness:
77 78 79 210 220 491
Rerouting coil harness: 71 72
Rerouting injector harness:72 80 94
Recreating injector connectors: 324
Relocating EVAC solenoid: 57
Relocating Negative battery cable: 94
Relocating EVAC hose: 210
Relocating Positive battery terminal: 245
Relocating Coils:
64
Relocating PCM: 491
Remounting fuse box: 555 582
Polishing Water Vapor tube: 118
Polishing the front of cylinder head and welding bolt holes: 154
Polishing Power Steering Pump:
Polishing Oil Cooler:
Polishing T-Bolt clamps and Thermostat housing: 232
Before......
After.........
Polishing power steering bracket:
282 285 292
Before........
After.........
Refinishing the generator/alternator: 428
Before........
After sanding........
Done .........
Refinishing front drive:
water pump, alternator brackets: 390 430 483
Before.......
After.......
Refinishing AC compressor: 422
Before.......
After.........
Polishing AC lines: 457 464
Before.........
After.......
Refinishing motor mounts before sending to powder coating:
913 927
Refinishing cylinder heads before sending to Lingenfelter to get reworked: 931 981 990
Before......
After.........
Refinishing timing chain cover before sending to powder coating: 1011
Before......
After........
Prepping intake for Powder coating: 388
Create fuel lines: 129
Refinishing Vararam intake: 143 220
Before.....
After......
Cutting coil wires to size:
204 210
Redoing water vapor line:
206
Refinishing driver side strut tower:
257 359 377 383 451
Before......
After......
MISC:
How measuring bolts sizes: 152
Cutting Intake coupler in half: 317
Part used on Project so far:
ARP bolts: This is a partial list of all the bolts I've replaced. NOTE: when ordering ARP bolts, you can purchase them in sets of 5 or individual bolts. The sets of five and the individual bolts have different parts number:
1 - Intake bolts (This is a kit that comes with all 10 bolts. http://www.summitracing.com/parts/ARP-430-2101/?rtype=4
2 - Throttle Body: http://www.summitracing.com/parts/ARP-770-1006/
3 - Fuel rails. Note: Other fuel rails might require different size. http://www.summitracing.com/parts/ARP-770-1003/
NOTE: OEM rails will use the shorter 6MM by 1 by 20MM length. http://www.summitracing.com/search/?...770-1001&dds=1
4 - Water pump (This is a complete kit): http://www.summitracing.com/parts/AR...3202/?rtype=10
5 - Pulley tensioner: (this part # is for a set of 5 - you will only need three but it's more cost effect to get the bulk
amount) http://www.summitracing.com/search/?...772-1005&dds=1
6 - Power steering: Quantity: 3 Size: 10MM X 1.5 by 70MM, Part #: M12AM70-12C
7 - Water vapor lines - Quantity: 2 Size: 6MM X 1 by 20MM Part #: M8AB20-12
Two bolts for passenger cylinder head: http://store.yoastfabrication.com/servlet/-strse-13/Camaro-Head-Plate-Bolts/Detail
Stainless fender bolts and washer: http://www.ringbrothers.com/index.cf...Product_ID=369
Oil Filter: Pure Power http://gopurepower.com/
Lokar dip stick: Part #: XED-5008
Coil Relocation set-up:
1 - Coil bracket:
http://www.ebay.com/itm/LS1-LS6-coil...item43a9492ba2
2 - Plug wires: Manufactor: MSD Part #: 31193 Description: MAD 8.5MM Super Conductor Spark Plug Wire Set Link: http://www.summitracing.com/parts/MSD-31193/?rtype=10
3 - 4 Plug wire boot and terminal also needed: http://www.summitracing.com/parts/MSD-3304/?rtype=10
NOTE:
If your using the red plug wires, you wont need to purchase the additional boots and terminals, it's included: http://www.summitracing.com/parts/MSD-32079/
4 - Wire Separator: Manufactor: Taylor Part #: 42700 Description: Ignition Wire Loom/Separator, Nylon, Black, 7-8mm, Set of 6 Link: http://www.summitracing.com/parts/TAY-42700/?rtype=10
5 - Wire heat sleeve: Manufacturer: DEI Part #: 010612 Link:http://www.summitracing.com/search/?...20010612&dds=1
6 - Spark Plug Boot Protectors: Manufacturer: DEI Part #: 010512 Link: http://www.summitracing.com/search/?...20010512&dds=1
Fuel Lines and Fuel rails Set-up:
Fuel lines and fittings: http://techafx.com/
Parts: T-609006DTBK
Description: -6 90 Deg. PTFE Hose End (AL/ Black)
Quantity: 1
Parts: T-600006DTBK
Description: -6 straight PTFE Hose End (AL/ Black)
Quantity: 2
Parts: T-824-06-2
Description: -6 Male An/JIC Flare Tee - Black
Quantity: 1
Parts: T-63006-10
Description: -6 Black Wrap SS Braided Teflon hose
Quantity: On web site it's sold in 10 Ft length.
NOTE: If you call, you can purchase by the foot. I got 5th and use the rest for the EVAC relocation.
Black anodized fuel rails with no company branding on them: http://www.wegnerautomotive2.com/
NOTE: I don't have a part number but you can call Casey Wegner and he will take care of you.
Wiring harness:
Injector connectors, map sensor and throttle body extensions: http://www.casperselectronics.com/store2/
90 degree injector heat shrink boots: http://www.bmrs.net
Harness tape: http://www.eficonnection.com
Russell Harness sleeving: All 4 sizes
Wire Wrap: Manufacturer: Painless, Part#: PRF-70902Description: Protective Sleeve, Power-braid Wire Wrap, Black, .500 in. Diameter, 10 ft. Length, Each Link: http://www.summitracing.com/parts/PRF-70902/
Wire Wrap: Manufacturer: Painless, Part#: PRF-70916, Description: Protective Sleeve, Power-braid Wire Wrap, Black, 1 in. Diameter, 12 ft. Length, Each
Ground cable: http://genuinedealz.com/
Carbon fiber valve covers: http://www.katechengines.com
Billet tensioner: http://www.katechengines.com
Powder coated intake: http://thepowdercoater.com/index.shtml
Cold Air Intake setup:
Intake:
http://www.vararam.com/camaro-ramair-unit2.html
Black coupler:
T-bolt clamps for intake:
http://www.mcmaster.com
Part #: 5312K23 Description: Type 300 Series Stainless Steel T-Bolt Hose and Tube Clamp, 4-1/32" to 4-11/32" Clamp Diameter Range, 3/4" Band Width
Vacuum Line and Fitting:
XRP
Parts: 209006BB
Description: -6 90 Deg double swivel hose end black
Quantity: 1
Parts: 250006
Description: -6 37 Deg male flare push-on hose end
Quantity: 1
Hose: Parts: 3106-00
Description: - 6 XR-31 Nylon Braided Race hose
Quantity: Depends on how your routing it. 2 Ft minimum.
XRP water vapor set-up: http://www.xrp.com/
Parts: 82446
Description: Special Tee, Flare -4 Male w/ -6 Male Branch
Quantity: 1
Parts: 109004SN
Description: -4 90 Deg Hose End Super Nickel
Quantity: 2
Parts: 100004SN
Description: -4 Straight Hose End - Super Nickel
Quantity: 2
Parts: 100006SN
Description: -6 Straight Hose End - Super Nickel
Quantity: 1
Parts: 3106-00
Quantity: 2 FT
Parts: 3104-00
Description: -4 XR-31 Nylon Braided Race hose
Quantity: 2 FT
The blocks are from http://www.krcpower.com/ecommerce/cooling-system-components/ls-bypass-hose-kits/4-water-bypass-adapters-pair.asp
Radiator hose replacement:
Aluminum tube:
Coupler:
Clamps:
Flex-a-lite radiator:
http://www.flex-a-lite.com/auto/html..._radiator.html
Meziere electric water pump: http://www.meziere.com/ps-1507-1520-wp329n.aspx
Innovators West Front Drive: http://www.innovatorswest.com/8-Rib-...sion-Kits.html
Billet strut tower, over flow and radiator caps: http://www.lsrperformance.com/dress-...vy-camaro.html
Windshield washer relocation kit: http://www.apex-speed.com/apex-motor...t-1234567.html
Motor Mounts:
http://prothane.com/
Improved Racing Oil Pan Baffle: http://www.improvedracing.com/
NOTE:
I will update parts list as we go.........
Moreno1 is offline   Reply With Quote
Old 12-16-2011, 12:44 AM   #2
Disco69
The Backbone!
Disco69's Avatar
Drives: '11 VR 2SS/RS M6, 01 Jeep TJ modded
2011 Victory Red 2SS/RS
2001 Jeep TJ Wrangler Sahara
Disco69 is offline   Reply With Quote
Old 12-16-2011, 12:45 AM   #3
Slideways
Slideways's Avatar
Drives: '10 Camaro 2SS
Subscribed , great idea !
Slideways is offline   Reply With Quote
Old 12-16-2011, 09:58 AM   #4
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
Here are a few things I have done to clean up the engine compartment. First was to get rid of the engine cover and top intake manifold cover. I installed the TechAFX heater hose kit. It also includes a new fuel line. I polished the fuel rail and rotated it 180degrees.
The Roto-Fab Radiator cover cleans up the top of the radiator.
A Katech Billet Belt Tensioner looks better than the factory one.
I made a new PCV hose and routed it under the Throttle Body instead of over the top.
The cold air intake is by ADM Performance. I think it is the best looking piece on the market. The washer bottle is by Roto-Fab.
MRGOODWRENCH3 is offline   Reply With Quote
Old 12-16-2011, 10:20 AM   #5
Ravener
Ravener's Avatar
Drives: 2010 2SS RS M6 Blk
I like what you've done there....but truth be told is doesn't "clear up" the plumbers clutter the OP pointed out regarding our egine bays. Removing the engine cover just exposes the mess beneath lol.
418 LS3, custom cam, tuned vararam, ported tb, Kooks stepped LT's, Kooks Hi-Flo cats and 2.5" street sleeper cat back, 18% UDP, crap stock rear tire size 12.03 @ 117 mph.
Ravener is offline   Reply With Quote
Old 12-16-2011, 10:33 AM   #6
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
looking real good. Looks like you actually have a muscle car engine rather than a piece of plastic
AngelSpeedFreak is offline   Reply With Quote
Old 12-16-2011, 10:34 AM   #7
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
The only thing else that mr good wrench could do is a coil relocation kit and get some new valve covers. you really can't do much else unless you are going to do some major surgury. ADM did a build where they moved the fuse box out of sight and that really cleaned to motor bay up some, but that is pricey.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 12-17-2011, 04:43 PM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I cleaned mine up by using 2012 Camaro heater hoses, flipped the fuel rail 180 degrees, removed the intake manifold cover and powder coating the coil brackets. In the next month I will make a few more changes.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 12-18-2011, 01:30 AM   #9
Moreno1
Drives: G5.R
Lackonblacksls sent me these pictures. This things is Bad Ass. Not one original factory hose on it. 427 13.7 to 1 compression!
Old 12-18-2011, 02:05 AM   #10
camslambam
Drives: 2010 SS, 06 SRT10 Ram
People actually clean under the hood?
camslambam is offline   Reply With Quote
Old 12-19-2011, 06:31 PM   #11
blackonblacksls
Drives: 2011 2ss/rs
Yep my car with the black fast with blue letters
blackonblacksls is offline   Reply With Quote
Old 12-19-2011, 07:43 PM   #12
PAUL SS
PAUL SS's Avatar
Clean, no. Don't allow it to get dirty, yes.
Old 12-19-2011, 07:47 PM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
yup
Click to view my build thread
Old 12-20-2011, 12:47 AM   #14
Moreno1
Drives: G5.R
Looking for thoughts on powder coating the stock intake in a "wrinkle Black' finish. It will be subtle but slightly different than factory. Perhaps a more cast aluminum look. I'm going for a industrial high tech look. Not to showing or Bling.
Some thing like this: http://www.camaro5.com/forums/showthread.php?t=110331
Let's hear it.
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 12:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
