TireRack
Old 03-04-2014, 08:18 AM   #1
claire_zl1
claire_zl1's Avatar
Drives: Summit White 2013 ZL1
JDP Color Shift Halos
Hi! I was wondering if anyone has had experience installing these? I've been looking into buying some but I was wondering if it's a pain to install, how long it would take, and what you exactly have to do. Thanks!
claire_zl1 is offline   Reply With Quote
Old 03-04-2014, 09:30 AM   #2
Leem12
Leem12's Avatar
Drives: 2012 Chevy Camaro (RS)
I'm thinking about buying them also
Leem12 is offline   Reply With Quote
Old 03-04-2014, 09:38 AM   #3
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
If you want the best on the market get the NightOwl system not JDP.
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 03-04-2014, 09:38 AM   #4
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
It took me 8 hours but that is with a break and also waiting for my stupid electric drill to charge. It is a good system but they lack in somethings.Is it a good system for its price yes it is. On a scale from 1-10 on difficulty i would put it at a 6. That is just because it is so damn annoying unscrewing those tiny bolts out of the headlights. I drop some of them into the headlight and you probably will too and you got to shake the crap out of it to get it out. It is totally worth doing though!
SoFlo Muscle Car Group
Miami/Broward
954camaro is offline   Reply With Quote
Old 03-04-2014, 09:41 AM   #5
954camaro
954camaro's Avatar
However, like Camarokid said if you want the best you go with nightowl. That is what i did.
Miami/Broward
Old 03-04-2014, 09:47 AM   #6
ka1
ka1's Avatar
Drives: 2011 2SS
3rd'd
ka1 is offline   Reply With Quote
Old 03-04-2014, 09:53 AM   #7
SpaceMarine
Drives: 2011 Camaro 2LT/RS
Originally Posted by ka1 View Post
3rd'd
Or do this instead: http://www.camaro5.com/forums/showthread.php?t=255417 and avoid the ugliness of the led dots in the aftermarket halos.
Make sure you get the right numbers for the resistors though!
Have fun!
SpaceMarine is offline   Reply With Quote
Old 03-04-2014, 10:01 AM   #8
CamaroKid300
ace5.org
Drives: 2017 ZL1 M6
Have fun!
NightOwl/JDP you do not see the LEDs in the halos. It's a clean ring of light unlike AAC. Looks stock other than being able to use any color you want.
Stock...For Now.
Old 03-04-2014, 10:36 AM   #9
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I've had both kits and the Night Owl kit is hands down the best. They both install the same, but a couple of things to consider are that the Night Owl kit allows for color correction. If your color is off just bit or you want a slightly different color, you can dial it in with Night Owl. The JDP kit tends to have a problem with white and your stuck with it. The other big things is that Night Owl is expandable and you control it ALL from your smart phone. Adding light with the JDP kit is difficult. Most end up with a couple of controllers which tend to be generic BTW, so others might be able to control your lights also. The Night Owl kit sets up a unique Wi-Fi link that only you have access to.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-04-2014, 10:41 AM   #10
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
GEN5DIY.com also has a kit that is similar to both and i think is the better priced out of all of them. I have the JDP kit and love it but if you want the mass amount of options then the Night Owl kit has it all. Regardless of which kit you choose they all have great customer service just depends on how much you want to spend.
c_LoW29 is offline   Reply With Quote
Old 03-04-2014, 12:04 PM   #11
ka1
ka1's Avatar
Drives: 2011 2SS
Have fun!
My halos don't have dots. The nightowl system only works for those with the RS headlights.
Old 03-04-2014, 12:29 PM   #12
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
NightOwl is the best of the best. Also, see here.
http://www.camaro5.com/forums/showthread.php?p=3217556
sjmautoprod is offline   Reply With Quote
Old 03-04-2014, 06:08 PM   #13
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
I started with the JDP kit and upgraded to the NightOwl controller. The JDP kit is great for someone just wanting a basic halo kit that looks factory. The NightOwl kit is the top of the line kit on the market but it's their controllers that set them apart from anyone else. Their customer service is also 2nd to none. JDP and Gen5DIY are also great vendors.
I am actually going to be helping a buddy install the JDP kit in 2 weeks and I expect to have it done in about 3 hours. The key is to get a long (2") T-10 Torx bit and a swivel socket. It will make the job a whole lot easier and save your sanity in the process.
Deke736 is offline   Reply With Quote
Old 03-05-2014, 08:34 PM   #14
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
just installed the night owl kit and it is second to none! You can do so much with this system.
Chad's ZL1 is offline   Reply With Quote
colorshift, halos, jdp
