TireRack
Old 08-30-2014, 09:12 PM   #15
xRedsox
Night Fury
xRedsox's Avatar
Drives: 2016 Golf R
Take it to the dealership and have them replace it, it should take about 1-4 hours depending on the dealership having a body shop. Also, you might have to wait a week or two because of the part being on order.
2014 2LT RS A6
Mods: K&N Intake, Magnaflow Axleback, BMR Strut Tower Brace, VTC Throttle Controller, Tune.
xRedsox is offline   Reply With Quote
Old 08-30-2014, 09:47 PM   #16
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
Originally Posted by 191185 View Post
Do you know how to pull the headlight assembly, does the front fascia have to come off ?
The front fascia definitely has to come off. It's not hard to get it off though. You really need 2 people to handle it and a soft place to put it, so you don't scuff it up.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 08-30-2014, 09:55 PM   #17
Rocky1974
Rocky1974's Avatar
Thanks. Is this a common problem ? Or am I in the minority ?
Also, are there any other super common issues with the 2010's ? I know every car has it's small problems, and usually on a forum everyone is well aware and they are dealt with fairly easily..
Anything else to watch for on a 2010 ?
Thanks ! And by the way I just joined and look forward to learning a lot here
The early '10s were famous for the rear spoilers coming loose. I'd think that they were all fixed by now or the spoilers would have fallen off. Is yours a stick or auto? Some of the early TR6060s had defective output shafts, but again, if it hasn't broken by now, it's probably not going to.
Old 08-30-2014, 10:33 PM   #18
Rocky1974
Rocky1974's Avatar
Oh, I saw your car in another thread. You've got a V6. You don't have a TR6060, even if you do have a manual.
Old 08-30-2014, 11:19 PM   #19
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
light
Ya the front fascia must come off to remove the headlight. But you can access from under the hood the headlight bulb and turn signal bulb. Maybe they forgot to put the haedlight bulb cap on because thats alot of water in there and looks like maybe some access hole is open.
if you just bought it then it should come with some type of warranty. But in my state that would be a safety fail and i wouldnt get a safety inspection for moisture in the headlight.
plus with it being used maybe the previous owner opened the lights up for aftermarket lighting and didnt seal them good?
mycamaro2011 is offline   Reply With Quote
Old 08-31-2014, 02:12 AM   #20
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Myself and my brother have 2010s neither have had headlight moisture issues, so I don't think it's a common issue.
I don't have HIDs in mine though, my brother does.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 08-31-2014, 09:00 AM   #21
Swacer
Drives: 2018 GT350
I actually just replaced my headlight for leaking and hazing over.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 08-31-2014, 08:50 PM   #22
191185
Drives: 2010 2LT/RS 6A
Was it under warranty ? If not, what was the total bill if you don't mind me asking ? So I have an idea of what to expect.
191185 is offline   Reply With Quote
Old 09-01-2014, 06:32 PM   #23
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
This happened to mine. I had to replace it. My dealer was an a** about it so I never went back to deal with them and went ahead and got a refurbished one.
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 09-03-2014, 11:31 AM   #24
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
After certain types of weather instances such as very quick shifts in humidity and dry air, a minimal fogging up of the headlamp is normal. It should go away shortly after or once the headlights are turned on. These are vented headlight systems, afterall. They aren't 100% sealed.
Heavy condensation like what is shown in the pics is not normal.
nUcLeArEnVoY is offline   Reply With Quote
Old 09-04-2014, 12:20 PM   #25
191185
Looks like the dealer is going to pay half of the cost of assembly and labor .. works for me. going aftermarket headlight assembly for $500 and around $250 labor I believe, and I will be paying half that ...
Thats better than nothing .
Old 09-04-2014, 12:37 PM   #26
Swacer
Drives: 2018 GT350
It was replaced under warranty. I'm under warranty until 3/2015
Has anyone bought Oracle Headlights?? I have questions!! ihaveacamaro Cosmetics and Lighting Modification Discussions 22 06-09-2010 08:04 PM
keeping headlights looking new Darth_Emma Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 19 03-03-2010 10:16 AM
Do our headlights come on with our wipers? wrek 5th Gen Camaro SS LS LT General Discussions 10 10-23-2009 04:30 PM
Swap RS headlights with non RS headlights rallyyellow Cosmetics and Lighting Modification Discussions 14 10-09-2009 04:49 PM
Condensation in late 4th gen headlights? MAC 4th Generation Camaros 27 06-30-2008 01:53 PM
