02-17-2024, 08:43 PM | #1 |
Drives: Chevy Camaro Join Date: Feb 2024
trunk flooded on my zl1
hello, I finally was able to purchase my dream car a zl1, not 2 weeks pass were it started to rain and my trunk flooded here in LA
there was about an inch of water in the trunk. I was able to clear out the water and dry all the components however my screen does not turn on nor can I hear any sound. my back up camera works when I put it in reverse but that's about it. is there anyone here that fixed the issue without having to take it to the dealership? if so the help would be appreciated. thank you. |
02-17-2024, 09:07 PM | #2 |
Drives: Chevrolet Camaro Join Date: Feb 2020
Ouch - I may not be much help here, but your battery and important fuse box is right there in the trunk. Along with several other modules. I suppose best case, one or more of your fuses popped and saved some or all of it. If so, I'd make sure it's all bone dry before trying new fuses (if they are blown). If the fuses aren't, I'm afraid you may have bigger problems.
Check your fuses and cross your fingers. |
02-17-2024, 09:41 PM | #3 |
its funny that every thing on this image works fine its just the screen and the radio.
smh I may just have to take it to the dealership. thanks for the reply dirt bike I appreciate it |
02-18-2024, 07:51 AM | #4 | |
https://www.camaro6.com/forums/showthread.php?t=611576 |
02-18-2024, 10:41 AM | #5 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
https://www.camaro6.com/forums/showthread.php?t=613210 |
02-18-2024, 12:21 PM | #6 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
If this is a new car it should go right back to the dealer.
02-18-2024, 02:15 PM | #7 |
Drives: 2023 2SS Convertible Join Date: May 2009
Yes - times 100! I would think this is all warranty. That trunk is supposed to be sealed for rain. That is BS.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
02-18-2024, 02:35 PM | #8 |
Damn! I wonder what the cause is for some and not others? I wonder if I should install a bilge pump.
02-18-2024, 04:25 PM | #9 |
Drives: VOM 2022 2SS Join Date: Feb 2022
WTF, I've wash the Camaro (22 VOM 2SS)by hand with tons of water on the rear including the under carriage many times. Never noticed any yet. That's not supposed to happen. At least not like my first new car in 1976 a Cougar XR7 that leaked from the top back window. Take it back ASAP if new and have them fix it under warranty.
02-18-2024, 04:32 PM | #10 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
what year ?
02-18-2024, 04:33 PM | #11 |
02-18-2024, 07:08 PM | #12 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Yes, you may not like your dealership and you may want to do it yourself but taking it to the dealer protects you against any down stream issues from the leak.
Worst story ever was a Cadillac Eldorado owner had a flat tire in the winter. Went to get the spare and it was under ice from a water leak that froze. If it’s under warranty take it to the dealer.
02-19-2024, 05:40 AM | #13 | |
Drives: 2023 Camaro SS 1LE Join Date: Apr 2019
Man that stinks. Like most have said if it is under warranty take it to the dealership to fix and to avoid any hassle(s) if it comes up again.
And, this thread jogged my memory. A few months ago I saw this vid from Hot 1LE that talked about this issue. May be minor but hope it helps. Last edited by sklippi2018; 02-19-2024 at 05:41 AM. Reason: verbiage |
02-21-2024, 09:33 AM | #14 |
Here is a link to a service bulletin on the issue of water in the trunk: https://static.nhtsa.gov/odi/tsbs/20...81677-9999.pdf
It specifies other possible causes for the issue beyond the two mentioned in the video: Last edited by The Maverick; 02-21-2024 at 09:49 PM. Reason: Fixed link, thanks to Whoomba! |
