Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
Old 01-16-2024, 07:43 AM   #1
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
Rear Window Sticker Removal
Some A-Hole in my apartment complex put a 6x6 sticker on my convertibles rear window. I tried to peel it off, but could only get little pieces off.
Before I try something that may ruin the rear window or top, is there a way to safely remove stickers from our rear convertible windows?
I tried searching the forum, but the search feature doesn't seem to be working.
Glenn
2017 Camaro 2LT RS Convertible
truckrglenn is offline   Reply With Quote
Old 01-16-2024, 11:36 AM   #2
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
Try a little heat. Or get it off the best you can and then use some wax and silicone remover to rub the rest off.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 01-16-2024, 01:14 PM   #3
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
I've been using 3M adhesive remover for years. It is safe on paint, plastic, etc. It removes stickers and glue very quickly and safely. However, I have never tried it on clear plastic, if that is what your window is made of. I'd test it on a small spot first, but my guess is that it will work just fine. I pick it up at my local NAPA if you have one near you: https://www.amazon.com/3M-General-Pu...SmU&dib_tag=se
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 01-16-2024, 08:03 PM   #4
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
Dampen (but don't drench) a soft cloth or rag with warm water, place it on top of the sticker, and let it soak in for ~10 minutes. The sticker, and maybe even most of the adhesive, should come right off with gentle rub.
If any adhesive left, get the stuff MT suggests, and that should be fine to use on the glass if the directions don't say otherwise. (I'm guessing you'll want to avoid getting any of it onto the top's fabric though.)
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
Old 01-16-2024, 08:58 PM   #5
truckrglenn
Thanks everyone. I was leaning towards the soaking method, but wanted to hear other opinions.
I think that I'll wait for the weather to warm up. I just glanced over at my weather station and it's show 1.9°F.
Glenn
Old 01-17-2024, 06:44 AM   #6
NashZL1
Drives: 2022 Camaro ZL1
Highly recommended. I keep this product on hand. Works great.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2016 Hyundai Equus Ultimate
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 01-17-2024, 09:45 AM   #7
Weege
Weege's Avatar
Drives: 2017 2SS convertible M6, NPP, MRC
So what was written on the sticker? Inquiring minds want to know.
Did you hear about the restaurant on the moon?
Great food
No atmosphere.
Weege is offline   Reply With Quote
Old 01-17-2024, 10:05 AM   #8
truckrglenn
I'm sure that you'll find it disappointing. I paid my updated registration online but never received the new stickers. I had forgotten about it until this. I went back online and it shows that I paid back in Aug. 2023. My apartment complex is real anal about this. You're not even allowed to part a motorcycle here unless visiting. That's why I have a garage here. That line, top right is just a shadow or reflection.
Glenn
Old 01-17-2024, 10:40 AM   #9
MT-SS1LE
Is that window glass or plastic? Sorry, not familiar with the convertible.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-17-2024, 10:49 AM   #10
The Chief (tm)
MT,
Luckily these days, it's glass. So when I added my note to the OP, I said that the product you suggested would almost definitely not cause any problem, if it was needed to remove any residual adhesive.
'99 4Runner 367K
'94 ST1100 146K
Old 01-17-2024, 11:33 AM   #11
MT-SS1LE
Originally Posted by The Chief (tm) View Post
MT,
Yeah, the 3M adhesive remover will remove that with no problem. I've used it on glass to remove adhesive many times and it works awesome. Heck, on glass you could probably use Acetone/nail polish remover with no issues. Just don't get it on the paint!
ΜΟΛΩΝ ΛΑΒΕ
Old 01-17-2024, 02:59 PM   #12
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Or the more commonly available Googone in gel form as to lessen having it run down on your ragtop. And a crisp new razor blade with said cleaner/lubricant is no harm to the glass for adhesive removal
CalgaryZL1 is online now   Reply With Quote
Old 01-18-2024, 07:57 PM   #13
truckrglenn
@CalgaryZL1 I won't get close to it with a razor blade. I notice that you drive a coupe.
Glenn
Old 01-18-2024, 08:24 PM   #14
CalgaryZL1
CalgaryZL1's Avatar
I didn’t say a machete, I said a small razor blade to carefully remove the sticker. It’s no different than getting close to the paint on a Coupe.
