dave@hennessey
Old 04-06-2014, 01:34 PM   #1
2011Black2SS
Drives: 2017 ZL1 M6
What to use to removed "baked" on brake dust
After a track day, my front wheels were covered in brake dust which is to be expected. When I went to wash them it appears that in certain areas the brake dust "baked" onto the wheel. What can I use to clean the wheels? They are the black ZL1 wheels.
2017 Nightfall Gray Metallic ZL1 M6
2014 Black GMC Serria Z71
1996 Red Z28
2011Black2SS is offline   Reply With Quote
Old 04-06-2014, 01:50 PM   #2
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Did you use a wheel cleaner? If not try that first of all.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 04-06-2014, 02:20 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
If wheel cleaner doesn't work you might look into some clay. Just keep it separate from what hits your paint.
Sent from my DROID RAZR HD using Tapatalk
Firefighter is offline   Reply With Quote
Old 04-06-2014, 03:38 PM   #4
ec1990
Drives: 2012 AGM SS
Wheel Cleaner, Iron X, etc...
ec1990 is offline   Reply With Quote
Old 04-06-2014, 06:53 PM   #5
2011Black2SS
Drives: 2017 ZL1 M6
Well, I found some wheel cleaner that didn't damage the paint and it along with some elbow grease and a tooth brush worked. Was hoping for something easier though, but thanks for the replies.
1996 Red Z28
Old 04-06-2014, 07:03 PM   #6
JTruck
JTruck's Avatar
Did you pick something up from your local store? There are some great wheel cleaners out there that work amazing, sonax, meguiers, adams and others. Just make sure to agitate and not let it dry on. FYI, for the future. (Look around this forum for some of the before and after pictures of detailer's domain and you can really see how the stuff works.)
Either way, got them cleaned, go hit the track again now.
Old 04-06-2014, 07:38 PM   #7
2011Black2SS
Drives: 2017 ZL1 M6
Yeah I found some mequiers that was safe for painted wheels.
1996 Red Z28
Old 04-06-2014, 07:40 PM   #8
JTruck
JTruck's Avatar
That's what I use. Sometimes it may take a few applications to make it easier to come off.
Old 04-06-2014, 08:19 PM   #9
flyinlow89
Smoke Alotapotomous
flyinlow89's Avatar
Drives: 2010 Camaro SS
In most cases I recommend the safest method first. Soap and water. I rarely use wheel cleaners because it's not often they're really needed. Otherwise I will move on to sonax. Very safe and works well. I have no experience with Adams equivalent product so I can't touch on it.
2010 Camaro TT SS. AGP twin Turbo
http://i377.photobucket.com/albums/oo216/flyinlow89/siggy.jpg
flyinlow89 is offline   Reply With Quote
Old 04-07-2014, 08:15 AM   #10
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Deep Wheel Cleaner is ideal for baked on brake dust from a big set of Brembos. It's safe for ANY type of wheel, black ZL1 wheels included.
Just be sure to follow the two golden rules of wheel cleaning:
1) Don't use them when the wheels are hot
2) Don't allow the cleaner to dry on the surface, rinse thoroughly
Stand by those two and that brake dust will melt away. Once you have them thoroughly cleaned, I'd suggest getting a coat of Quick Sealant on them to make them easier to clean, both after normal driving and track days alike.
Adam's Polishes is offline   Reply With Quote
Old 04-08-2014, 09:16 AM   #11
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
For caked on brake dust, use Iron-X. Caked on means that the heat and rust-reaction of the iron has embedded itself into the pores of the wheel's finish. Traditionally, acid or alkaline cleaners are used, although these can have negative effects long term.
Iron-X dissolves the iron content (as well as decontaminates the wheel) so you can easily remove any caked-on dust.
Todd@Autopia is offline   Reply With Quote
