Old 02-02-2014, 12:30 PM   #1
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
all season tires???
Pirelli PZero Trofeo R
front: P305/30ZR19
rear: P305/30ZR19
Can anyone make a recommendation for a good 4 season tire with the same dimensions/profile as the trofeos???
Yes I will drive it in the winter avoiding the snow if possible. Not a snow tire but a 4 season performance tire. Back in 2004 I used Michelin Pilot Sports in the winter and they seemed fine.
I want to actually not trailer and just drive up to the glen once in a while and don't want to burn expensive trofeos on touring miles.
a less expensive tire woud be great too...Khumo?
any info appreciated...
tia,
backtotintops is offline   Reply With Quote
Old 02-02-2014, 04:28 PM   #2
macalot
macalot's Avatar
Drives: 1969 Z/28 + 2015 Z/28
I will need the same information as well, later this year.
macalot is offline   Reply With Quote
Old 02-02-2014, 10:56 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I searched on TireRack.com and found no all season 305/30-19 tires. They were all summer performance or competition tires.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 02-03-2014, 10:04 AM   #4
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Why do you need 305s if all ur doing is driving on street? Sounds like u will have commitd rims just get some 275-285s and call it a day.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 02-03-2014, 10:25 AM   #5
Col. Brain
Drives: 2012 Ram 1980 Malibu
buy a set of wheels for winter - probably stock Camaro and put snow tires on it
buy another set of wheels for daily driving (could probably get another set of z/28 wheels and add it to the car purchase) and put on summer perf tires
Col. Brain is offline   Reply With Quote
Old 02-03-2014, 10:42 AM   #6
backtotintops
Drives: 14 Z/28 0#
Thanks for the responses but I'm not looking for snow tires just touring tires that cost less than trofeos, have maybe 70% the performance or trofeos with much longer treadware and can operate "reasonably safely" down to zero degrees...I live in ny. Also I want it to look correct so preferably the same size/profile tire.
Old 02-03-2014, 10:55 AM   #7
crangie
crangie's Avatar
Drives: Camaro ZL1 #641
If you want to use the stock wheels, you will not find an all season nor snow tire which fits the rear with 11.5".
The best would be to get a spare set of wheels and run the Conti Extreme Contact DWS or the Michelin Pilot Sport A/S 3
you can check this review of tire rack http://www.tirerack.com/tires/tests/...y.jsp?ttid=177
you could use the Michelin PSS in 305/30, but I wouldn't personally drive them near zero degrees
crangie is offline   Reply With Quote
Old 02-03-2014, 12:26 PM   #8
yenkotown
yenkotown's Avatar
Drives: Hyundai 2.0T 10 former Corvettes
You need to use a 26.2 OD tire. You can use a 265/35R19 as a snow tire if it carries the correct air pressure and load rating. What do you think they do all over europe ....... 4 winter tires ? All Season tires are NOT snow tires and never should seriously be used that way. If you buy a $80,000 car you should probably use the correct tires for it. You can vary OD 3% .
yenkotown is offline   Reply With Quote
Old 02-03-2014, 01:41 PM   #9
backtotintops
Drives: 14 Z/28 0#
how about these Nitto INVO
http://tinyurl.com/mpraac2
...high treadwear @220/y speed and the correct size...AND CHEAP!!!...a good tire to get to the track. Any thoughts appreciated???
read the reviews..a guy even mentions snow and reviews all over the net say very good in the rain...so these could be track rains too.
Old 02-03-2014, 02:35 PM   #10
DavidW
Drives: 2013 ZL1 Vert Auto IOM
Continental Extreme Contact DWS 295/30/19 $257 each at tire rack
0.2 inches shorter and 0.4 inches narrower than stock
that is pretty damn close and something you would almost never notice
DavidW is offline   Reply With Quote
Old 03-07-2014, 11:26 AM   #11
backtotintops
Drives: 14 Z/28 0#
As someone noted on another thread the Michelin Pilot Sports might be a good daily driver and I found this tip about Costco from a Rennlist post 4/12:
"Finally bit the bullet and bought a set of the new Michelin Pilot Super Sports, had them installed last Tuesday. I bought them through Costco as the Price installed (about $1,170) was basically the same as several of the local shops and Tirerack with shipping and local install, but Costco included a road hazard warranty and nitrogen fill which would have been another $150-$200 with the other sources ( they also include free rotation but that doesn't do much good on a 996 with staggered sizes). I have to go back for another balancing as I have a slight shimmy between 75 and 90"
http://forums.rennlist.com/rennforum...ts-are-on.html
I know these are summer but I have driven them all year on 2 other cars...not in snow though.
