Old 02-24-2024, 04:20 AM   #1
okjuvkam
Drives: 2012 Camaro ZL1
Oil filter Numbers
Anyone bought oil filters lately ? Numbers on box does not match the one on the filters, these are from Rock Auto but a dealer here in Norway who stocks them say their inventory is the same 🤔
2012 ZL1 #428
okjuvkam is offline   Reply With Quote
Old 02-24-2024, 05:35 AM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
That number 19433934 is actually PF48E.
https://www.camaro5.com/forums/showt...99#post8281699
This is the new "E-Core" design oil filter and is slightly shorter in overall length than the PF48. The E-Core design has the same amount oil filter media and better filtration than the previous filter.
The Ultraguard UPF48R filter (U is for Ultra and R is for Racing) is black in color, has a thicker exterior shell.
The internal components are the same in both the UPF48R and the PF48 oil filters. The UPF48R can be used in applications where the PF48 is specified.
Btw. "GM requires the UPF48R for the LS9 application and is also used for the LS7 application as both engines are built at GM’s
Wixom Engine Performance Build Center."
Old 02-24-2024, 05:41 AM   #3
bsn
Drives: 2013 ZL1
The last AC/Delco I bought was like that-mine also said made in China. Possibly consolidating part #s. Returned it and got a Wix-also made in China:(
bsn is offline   Reply With Quote
Old 02-24-2024, 06:42 AM   #4
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Sounds like they cheaped out and used the old packaging on new the new filters.
They should have at least put a sticker on the box or a small note/disclaimer inside.
The beauty of the internet is that it allows you to check applications on line so you can make sure it is right.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
Old 02-24-2024, 06:40 PM   #5
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I purchased one and it looked just like the one you got, So I ordered another from somewhere else and it is like that one as well, Mine were always Black and Gold and came in a matching box, I thought the first was a knock off but then the I got the second just like it.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
