05-27-2016, 07:55 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: May 2016
Windshield fogging with the AC on.....
Anyone else in humid climates have an issue with the windshield fogging up with the AC on and in recirc mode? Seems like even with the fan speed on low and the temp setting at only 65*, I still get a good bit of fogging on the windshield. Almost like the defrost door is not closing off all the way when the AC is set to "head" and in recirc.. (Max)..
Experimenting with the defrost and temp settings, the ducts seem to change over properly and so does the temp/blend doors...however just a small enough amount bleeding through the defrost duct to fog the windshield.. Pretty annoying to have to turn the wipers on to clear the fog on a sunny day...it's done this every day that I've had it..(1 week). Just curious if this is common or mine has an issue.. I'd hate to have the dealer tearing into the dash.
05-27-2016, 08:08 AM | #2 | |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Turn off recirc. The heavy moisture just from breathing is not being dissipated if you don't introduce fresh outside air into the cabin.. AC does dehumidify but you have to give it some chance to exhaust the damp air. Recirc just keeps it in the car. Your breath is very moisture laden.
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav Last edited by Modshack; 05-27-2016 at 08:47 AM. |
05-27-2016, 08:22 AM | #3 |
Drives: 2020 Elkhart Lake Blue 1LT Z51 C8 Join Date: May 2009
All of my cars have done this for the past 35 years I have been driving. It's normal.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!! Sold 9/17/19 :( 2020 C8 ordered!! "The greatest sound in the world is a Rolls Royce Merlin over 100 inches" www.timadamsphotography.com |
05-27-2016, 09:11 AM | #4 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
05-27-2016, 09:17 AM | #5 |
Drives: 2013 Camaro ZL1 convertible IOM Join Date: Feb 2008
When I read the title to this thread, I knew you were in or near Houston!
05-27-2016, 09:31 AM | #6 |
So you are getting condensate on the EXTERIOR which must be cleared by the wipers? This is because the glass is cold and the outside humidity is high. Redirecting airflow off the glass should help. In recirc mode your duct temp is probably in the 50's once the system runs a bit. That is pretty cold air to blast directly at the glass.
05-27-2016, 09:37 AM | #7 | |
Guess I'll have to play with somethings like turning off recirc like the other poster mentioned.
05-27-2016, 09:38 AM | #8 | |
05-27-2016, 09:41 AM | #9 | |
I think this is more due to the fact there is air coming up out of the defrost vents when it shouldn't be. The fog pattern on the outside of the windshield is exactly at the place on the glass where the air from the defrost vent is coming out...
05-27-2016, 01:36 PM | #10 |
Drives: Future 6th Gen Owner Join Date: Feb 2016
05-27-2016, 01:54 PM | #11 |
Drives: 16 Camaro: Mosaic/2SS/A8/NPP/Custom Join Date: Aug 2013
Sucks because NTX and DFW have had Dallas type humidity the whole month!
'16 Chevy Camaro 2SS Auto - Mosaic Black l Kalahari Interior l NPP l Nav l Sunroof. Prismatic 22" concave Koko Wheels l Lexani Tires l GM Splitter l ACS Rockers l ACS Spoiler l BMR Drop l Limo tint l Smoked Lighting l Debadged l LEDs l WeatherTech l More to come... YouTube Channel:https://www.youtube.com/channel/UCq4...9-q-ccCuqVONUw |
05-27-2016, 05:09 PM | #12 |
Drives: Jeep Wrangler Join Date: May 2015
This has happened to me in every car I've owned. It's always humid here, though.
05-27-2016, 05:14 PM | #13 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Fogging windshield
05-27-2016, 06:21 PM | #14 |
Ran mine on the way home with the recirc off, it actually fogged up worse.. It was 85*, 95% humidity and raining. Trying to run the defrost and AC at the same time obviously did not help as if blew even more cold air on the glass. Once I went to defrost, put the temp at 80*, it finally cleared the fog off... But it got hot in the car quick.
Pretty annoying for sure.
