08-17-2017, 10:42 AM | #225 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Do I like that I get windshield condensation and a slightly ill fitting headliner? Absolutely NOT, and it shouldn't have that for $40+K. But, I didn't buy this car for Mercedes fit and finish. When I wind it out, or slam it into a corner, it's like, "What headliner/fogging"?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
08-17-2017, 11:22 PM | #226 | |
Used a piece of cardboard to make a template, transferred the shape to the vinyl, cut it out with a scissors. The black vinyl blends well with the dash and the lip molded into the vinyl keeps it in place. I was all done in 20 minutes for $5 and it works great! |
08-17-2017, 11:30 PM | #227 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Respectfully, the point is, we shouldn't have to lay a piece of vinyl in the windshield of a 2016-17 vehicle.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-18-2017, 01:12 AM | #228 | |
Just wanted to say there is a quick/easy/cheap workaround to the issue. No, it's certainly not ideal, but it works. |
08-18-2017, 04:43 PM | #229 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
If I see it starting to fog up I hit the defroster on high heat for a few minutes and it clears right up. I crack the windows so I get fresh air circulating.
08-18-2017, 06:06 PM | #230 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
When its 92 degrees out thats the last thing im doing.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
08-18-2017, 11:17 PM | #231 |
Drives: 2017 ZL1 Join Date: Oct 2016
Never had this issue on my 16 s s. Just got a zl1 and started noticing it today with the a/c on, although, it has been raining a lot and it very humid. My condensation is on the outside though, not inside. Wipers cleans it away..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
08-27-2017, 05:44 PM | #232 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Had the repair work done (removing foam blocks). And I figured out that it only fogs up (and much less than it did before)if I go with the following settings:
- Temp lower than 71 - Fan higher than 4 lights If I go more extreme than that, then I get the 2 spots over the vent and they're each about 2.5" wide |
08-27-2017, 07:41 PM | #233 | |
Windshield fogging
08-28-2017, 12:53 PM | #234 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Foam block removal?
08-28-2017, 02:18 PM | #235 |
Drives: 2017 Krypton Green 2SS Converible Join Date: Aug 2017
Tomorrow is the Day
Well it looks like I'm going tomorrow morning to Lou Bachrodt Chevrolet in Ft. Lauderdale to find out their recommendation on the condensation issue. I got all the "ammo" from the threads on this site. I hate the thought of removing anything from the car but as a "daily driver" the condensation issue really becomes a pain and it's somewhat embarrassing especially with my buddies that happen to drive Mustangs. I'll update my post later.
10-05-2017, 10:37 AM | #236 | |
Drives: 2017 Camaro 2SS Join Date: Sep 2017
Yep, i'm in STL and it has been doing it to my 2017 2SS also! Last edited by Ryan4290; 10-05-2017 at 10:48 AM. |
03-17-2018, 09:10 AM | #237 |
Drives: 2017 Camaro 2SS Hyper Blue Join Date: Mar 2017
I had the repair done and I can tell you it did not work. Back at the dealership for another go... fml.
06-23-2019, 11:13 PM | #238 |
Drives: Chevrolet Camaro 2SS Gen 6 Join Date: Jan 2019
I see this is an old thread but headed In with my 17 on wed. Also, anyone know anywhere you can lookup service bulletins by Vin? I have had several fixed the last 2 weeks and want to get them all do t this time before warranty expires.
