TireRack
Old 10-06-2018, 08:28 PM   #15
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I did a short WOT log. I was mostly looking how low my fuel pressure would drop with e85 I think is about e60 in the tank now. I have the JMS BAP not yet installed. As we knew e85 requires more pump. I'll see if BAP is enough I'm dropping down to 41psi at 8lbs boost (IDK why I don't get more boost with CAI). I didn't pulley up yet until I get the fuel pressure sorted out.
I was getting lots of wheel spin and started getting sideways at initial WOT. I see the drop in throttle opening and timing. I think that was at the shift.
silversleeper is offline   Reply With Quote
Old 10-06-2018, 09:19 PM   #16
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
OP- this is probably a dumb question, but are we talking about a 5th gen camaro here? The reason I ask is based on your avatar into. Are we talking about a C7?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 10-07-2018, 05:28 AM   #17
Bolt-onC6
Drives: 2017 Corvette
I do have a 2017 C7 Z06. Should be the same tune criteria for tb opening. I have asked the Corvette guys but nobody over there seems to know how to fix this.
Bolt-onC6 is offline   Reply With Quote
Old 10-07-2018, 06:35 AM   #18
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Ahhhhhh. I think that explains it. You'll probably need to do some reading on driver demand and torque-based tuning. I'm not an expert by any means, but an e92 controller works a lot differently than an e38 or e67 as I understand it.
Past Rides-
Old 10-07-2018, 07:13 AM   #19
Bolt-onC6
I've done a lot of reading and made some changes from what I have read. DD does get it open sooner but with a lot of knock retard. I'm running Boostane so it should not be too low octane fuel.
I thought the ZL1 had the e92 controller. At least in the newer.
Old 10-07-2018, 08:47 AM   #20
xc_SS/RS
Drives: 2010 Camaro SS/RS
Originally Posted by Bolt-onC6 View Post
Here's my results. With traction control on and off. Appears to be about the same. Initially 100% throttle then dropping before going 100% again at about 33 mph. And this was in 4th gear paddle starting about 20-22 mph. And as it hits 100% timing advance drops.
The files won't download so if anybody wants to see them post or PM me your email address.
Bryan, I added Commanded Throttle Actuator just so I see 100% and compare it to Throttle Position. Don't know why they read differently.
Have you disabled all torque management? Doing my own tuning as well so this has me curious. Mine goes open right away too from what I can remember from my logs
Post up a datalog and tune if you can.
Oh, what mods, if any, have you done?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-07-2018, 08:53 AM   #21
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Yeah, if you bounce over the the camaro6 side of the forum, you might find someone with experience (or the hptuners forum, for sure)
Past Rides-
Old 10-07-2018, 09:59 AM   #22
Bolt-onC6
Have not disabled all TM. Can't even get into the tranny file without sending it to HPT to unlock. I ran a 10.48@132.x mph before I put my overdrive crank pulley on but I also have a BMS filter, ported tb, catless pipe and my tune. If I can get some cooler air I think it should run a tenth or two better. My street logs show more power.
Tried to post the log but the site wouldn't let me.
I'll give them a try. Thanks...
Old 10-07-2018, 12:38 PM   #23
silversleeper
Big Crow
Drives: '13 ZL1
when you post hit the paperclip then browse for file.
Old 10-07-2018, 01:10 PM   #24
Bolt-onC6
Can't download a csv or hpl file. Invalid files.
Old 10-08-2018, 10:14 PM   #25
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
Gen 5 ZL1 has E67
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
