Old 12-24-2013, 05:56 PM   #1
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2016 Camaro 1SS
Gas?
Just got my C7, I've been putting premium in it. Not sure where my manual is, anyone figured this out yet?
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning
GAHDOOSH is offline   Reply With Quote
Old 12-24-2013, 06:21 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Premium only-at least 91....93 if avail...go to toptiergas.com for suggested brands
Old 12-25-2013, 07:55 AM   #3
Bolt-onC6
Drives: 2017 Corvette
And if you put in a small amount best to run a half to a gallon into a spare gas can to void the line with the residual 87 left in the line by the last customer.
Bolt-onC6 is offline   Reply With Quote
Old 12-25-2013, 01:18 PM   #4
urrtoast
Drives: Older
lol that's funny Thank you completely not necessary
urrtoast is offline   Reply With Quote
Old 12-25-2013, 01:40 PM   #5
Bolt-onC6
I suppose that's why you are probably a loser at the drag strip! Do you log your KR when you make a pass! Do you know for sure you have the octane you paid for! I log and when I put in two gallons at a time I make sure it's 93 octane which I'm tuned for and not a lessor number. You will get KR if you mix even small amounts of 87 with 93. Are you sure you know what you are talking about!
Old 12-25-2013, 03:18 PM   #6
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 12-25-2013, 08:13 PM   #7
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
Premium 93 octane.
Modern computer managed engines that were designed to use premium will "get by" on lower octane fuel but it should be avoided
A Corvette engine with 11-1 compression receives max power and max mpg from burning slow burning premium. The computer controlled engine will adjust to lower octane but the power and mpg drops off, hence, no cost savings
Always use premium.
bnall40 is offline   Reply With Quote
Old 12-25-2013, 08:41 PM   #8
Second Vette
Drives: 2011 Mustang
Originally Posted by bnall40 View Post
Premium 93 octane.
Always use premium.
Where do you find 93 Octane?
I live in S. California, there are three grades of Gasoline here 87, 89, and 91.
Second Vette is offline   Reply With Quote
Old 12-25-2013, 10:21 PM   #9
C7BOB
C7BOB's Avatar
Drives: 2012 C6 COUPE
OWNER'S MANUAL:
Use premium unleaded gasoline
with a posted octane rating of 91 or
higher.
* 2012 SuperSonic Blue coupe, gray int., A6, 3LT, NCM Delivery 04/16/2012 *
2005 LeMans Blue coupe, black int., A4, 1SB, NCM Delivery 4/25/2005
2003 gray/black coupe, A4, F55, 12CD, NCM Delivery 9/16/2002
2000 green/tan coupe, A4, NCM Delivery 5/16/2000
1996 CE silver/gray coupe, A4
1993 green/tan coupe, A4
C7BOB is offline   Reply With Quote
Old 01-19-2014, 08:00 PM   #10
Kim
Drives: 2014 Torch Red Z51
Premium gas
[QUOTE=C7BOB;7286470]OWNER'S MANUAL:
[FONT=Arial][SIZE=1]
higher.
I know the manual suggests premium fuel. I've heard the fuel that non brand name companies sell is manufactured by the main line companies. Is there any truth in that, and if so which companies can we count on to get the best fuel for our vehicles.
Kim is offline   Reply With Quote
Old 01-20-2014, 09:48 AM   #11
C7vette
Drives: 2009 CLK550
You can not, there is no 93 octane pumps in California. You might be able to get 100 octane racing fuel at some of the 76 gas stations but you might have to look around a bit. You can run a blend of 91 and 100 if you really want to run 93 in your car but I caution you the rate is probably $7-8 for 100 octane gas maybe more (I haven't check in a long time). I think your best bet for a 100 octane gas station would be around Newport Beach where Ferrari's, Lambos, Aston Martins, etc live.
C7vette is offline   Reply With Quote
Old 01-20-2014, 11:56 AM   #12
Drives: 2023 GMC Canyon, 2020 Colorado
Really?
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
