Old 08-15-2023, 12:19 PM   #1
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Katech KAT-A7763 Drop-in Dual Fuel Pump Module
Our phase one of our fuel pump is now released for anyone interested. We have 4 of these available right now which can be found in the link below (ignore the backorder).
https://katechengines.com/i-30498248...mp-module.html
This fuel pump has the full low level fuel performance of a factory Gen 6 ZL1 fuel pump module with all of the factory connection points. It features twin OEM grade high output fuel pumps that supply near double the amount of fuel as the factory.
Currently, this product is meant for the DIY'er, it has the studs to trigger the secondary pump on the top of the module hat. You can use any secondary fuel pump trigger just as you would with an aux pump.
We will be releasing a plug-and-play harness that will allow you to control both pumps with commanded fuel pressure via the factory ECU. Also, we will be releasing an inline post-pump filter kit that is serviceable external to the tank.
Katech_Zach is offline   Reply With Quote
Old 08-15-2023, 12:31 PM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great solution Zach! Love the plug and play turn key option... any idea when that will be ready?
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 08-15-2023, 01:55 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
DANG IT!!! I was 6-months too early, lol...
Would it be possible to run this set-up with the factory tune? Let's say I wanted to put this on a STOCK ZL1, with the intent on upgrading in the future. Could I run this with the OEM tune, until I need to bring the second pump on-line?
It's a smog-thing (CARB)...
'20 ZL1 Black "Fury"
Old 08-15-2023, 01:59 PM   #4
Katech_Mike
Drives: 2015 Camaro ZL1
We haven't tested that exact scenario but it should work without an issue. The primary pump is 100% controlled by the factory ECU.
Katech_Mike is offline   Reply With Quote
Old 08-15-2023, 06:05 PM   #5
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Hey Mike, output looks to be a LOT less than a Fore Double (and Triple, obviously) that typically run Ti Auto 274/285 pump combos. Can you substitute bigger pumps into your setup like Fore does or are you using smaller pumps to make them fit your bucket?
You should really redo the power levels based on forced induction and E85, since I don’t think you’ll see too many cars on the board making 1200 HP naturally aspirated…
Old 08-15-2023, 06:37 PM   #6
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
Can this be used with a jms if already installed?
Evansa22 is offline   Reply With Quote
Old 08-16-2023, 05:38 AM   #7
LloydK
Drives: 2020 SS Camaro A10
Excellent, I want one ��
LloydK is offline   Reply With Quote
Old 08-16-2023, 07:16 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for the information!
Old 08-16-2023, 07:30 AM   #9
Katech_Zach
I am not sure what standard Fore uses for their testing, but this was done at an OEM level supplier with all the line restrictions in place.
At full steam, this pump flows near double the capacity of the factory ZL1 fuel system without the requirements of -8an/-10an line + a regulator.
This fuel system is for the guy that wants up to 1000rwhp on E85 boosted. The pumps we used are much more efficient than the 274/285 fuel pumps above 40psi of fuel pressure. Generally speaking, the pumps used are the equivalent of twin 285's up top.
Below is the data from preliminary testing comparing to the factory C7 ZR1 LT5 fuel module. This was done on a mockup flow bench at a 3rd party, but as you can see, the data is different than the OEM level testing. However, it was good for A-B-C testing. If you want near double the amount of fuel from the factory, our solution is the most simple.
Old 08-16-2023, 07:44 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
How much power roughly would this pump setup support on E60 with a .83-.84 lambda target?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 08-16-2023, 08:05 AM   #11
Katech_Mike
This system is compatible with voltage up to 18v.
So yes, you can use a booster to increase the output if desired.
Old 08-16-2023, 10:22 AM   #12
Katech_Zach
It is hard to calculate from dyno variances between shops, areas, etc. Going by our comparison to the LT5 fuel system, I would take whatever horsepower number you have made on a factory LT4 low-side, and multiply that by ~1.75. I would imagine that would be a close ballpark.
Old 08-16-2023, 11:16 AM   #13
KingLT1
KingLT1's Avatar
Thanks for the response!
2016 NFG 1SS A8
Old 08-16-2023, 12:31 PM   #14
Ericdared
Drives: 2022 Camaro zl1
Awesome stuff! Will this work with a convertible as well? I haven't gotten to deep into it yet but I came across some posts that were some differences between the convertible fuel pumps vs the coups.
Ericdared is offline   Reply With Quote
