TireRack
Old 02-19-2013, 07:49 PM   #1
EddieCamaro
Drives: 2012 Camaro SS 45th Anniversary Ed.
2012 2SS HID Issue after fender bender
I got into a fender bender causing only 2 small cracks in the bumper and my upper grill got bent in. I then noticed the passenger side HID bulb was not working. The LED halo works just fine. I pulled the bulb and installed on the driver side and it works just fine. I could not find any damaged wires short of taking off my bumper cover. Any ideas before I drop $700 on a new headlight assy?
EddieCamaro is offline   Reply With Quote
Old 02-19-2013, 11:21 PM   #2
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Check your connections first, then make sure you have power to the lights. If that doesn't work out, try swapping your ballest to the drivers side and see what happens. Not a real good way to troubleshoot HID lights that i'm aware of except by swapping parts around.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 02-20-2013, 12:29 AM   #3
EddieCamaro
There is no visible damage to any part of the headlight. That is what is confusing me most. Fuse was checked and no issue there. Can the module fry from a simple bump?
Old 02-20-2013, 12:32 AM   #4
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Maybe the ballast got damaged. You can buy just the ballast for like 100 bucs
christianmotox is offline   Reply With Quote
Old 03-18-2013, 03:26 PM   #5
EddieCamaro
The headlight in question miraculously started working again about a week ago. It worked for about a day or 2 before it stopped again. Any idea what this might be? Harness?
Old 03-18-2013, 03:56 PM   #6
camaro2lt
camaro2lt's Avatar
Drives: 2010 Camaro 2LT VR/RS CGM Rally's
you sir have a bad ballast you need a new one.....or i might of come unplugged from the bulb
camaro2lt is offline   Reply With Quote
Old 03-18-2013, 04:19 PM   #7
EddieCamaro
thank you! do you think the dealer would cover this under warranty with the two small cracks in my bumper from my little fender bender? in other words, could the bad ballast be caused by the collision? if I'm SOL, can you link me to a trusted vendor?
Old 03-18-2013, 04:27 PM   #8
SSMickey
SSMickey's Avatar
If you filed this on your insurance, you should be able to get this covered by them. As for a dealer covering it, maybe. Just depends on there mood and your relationship with them. I myself would go to the service manager and tell them what happened and let things fall where they may. You might be surprised. Use a factory ballast.
Old 03-18-2013, 04:31 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
That would be an insurance claim, not a dealer warranty. That in turn means you should go ahead and pay out of pocket unless there is other damage to fix.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
Old 03-18-2013, 04:32 PM   #10
camaro2lt
camaro2lt's Avatar
i have a ballast pm me if you want one the dealer would not cover this because it might of been caused by the accident
Old 03-19-2013, 12:26 PM   #11
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
I would definitely suggest going to a dealership to see what exactly is happening with the component. Please let us know what you decide to pursue.
Brandon
Chevrolet Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
Chevrolet Customer Svc is offline   Reply With Quote
Old 03-19-2013, 09:14 PM   #12
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
Why not turn it in to insurance and get it all fixed?
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
2012, accident, camaro, hid
