Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Commercial Classifieds Marketplace > Bolt-Ons, Tunes, Engine Internals
Old 05-15-2014, 08:39 PM   #1
Corvette7Tuning
Drives: 2014 corvette stingray
AFE Cold Air Intakes Now at Corvette7Tuning!
  • Gain horsepower and torque
  • More miles per gallon
  • Washable, re-usable filter
  • Better engine performance
  • Fits 2014 Corvette Stingtray LT1
  • NO Computer re-tune required
  • Increase Horsepower and Torque. AFE Cold Air Intake Systems are computer designed to give your engine maximum air flow, which translates to more horsepower, torque and better fuel efficiency. This AFE CAI kit completely replaces your 2014 Corvette C7 restrictive stock factory air box and paper filter elements with a high flow AFE filter assembly for an increase of horsepower and torque at the rear wheels.
Superior Filtration. Each AFE C7 cold air intake provides superior air filtration, since it includes a AFE Premium Filter. AFE Performance High Flow Premium Filters can capture particles down to 2 microns in size. And best of all AFE Premium Filters are washable and re-usable, saving you money.
No Tune Required. This AFE Intake is designed to improve your V8 powered Corvette's performance without requiring computer reprogramming. Adding power just doesn't get any easier or more affordable.
Application. This AFE Cold Air Intake System is specifically designed to fit the 2014 V8 Corvettes with the LT1 V8 engine. No tune is required.
aFe is introducing the all new Momentum sealed cold air intake system for the 2014 Chevrolet Corvette (C7) with the V8-6.2L engine. This all new Momentum intake system resulted in 18 horsepower and 22 lbs. x ft. torque and outflows the factory intake by 42%. This system is superior in every way, from the one-piece sealed housing, to the massive air filter, roto-molded tube w/ built-in resonance chamber and premium hardware. This system uses a CAD designed, dyno-tuned, roto-molded intake tube & housing to achieve maximum power gains while maintaining a perfect fit. This is a direct bolt-on kit and requires no cutting or drilling on OEM parts.
Unique One-Piece Housing w/ Sight Window:
The one-piece sealed housing is used to eliminate the use of multiple components and ensure the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene and mounts directly into the factory location on the fender well to capture the coolest air available from the factory intake tract.
Roto-molded Tube:
This system uses a CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. This tube has a built-in resonance chamber to catch un-wanted air intake noises. Two billet aluminum fittings are mounted on the tube to provide a perfect connection with the factory vacuum lines.
Massive Cone Air Filter:
This Momentum intake system was designed around the largest filter possible to allow maximum performance and filtration. This cone filter has a massive 7" oval flange and is 9-1/2" tall Pro 5R filter media. The Pro 5R performance air filter features 5-layers of progressively finer mesh cotton gauze oiled media and is constructed with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel T-bolt clamps and a reinforced silicone hump coupler are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Proven Results:
After a rigorous design and testing phase, the results are in. The Momentum air intake system outflowed the factory intake by 42% and resulted in 18 additional horsepower and 22 lbs. x ft. torque.
Power, Protection and Simplicity.
*Note: This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
- See more at: http://www.corvette7tuning.com/afe-c....rVHCqg8u.dpuf
2014 Corvette Stingray Parts & Accessories
Lowest Prices & Free Shipping!
www.Corvette7Tuning.com
Corvette7Tuning is offline   Reply With Quote
Old 05-20-2014, 10:37 PM   #2
Corvette7Tuning
First batch has shipped. Next batch of 2014 Corvette cold air intakes are shipping out in about a week. Get your order in today!
Old 06-03-2014, 10:38 PM   #3
Corvette7Tuning
2nd Batch of AFE Cold Air Intakes for the 2014 Corvette Stingray has shipped today. We are now filling orders for batch #3. Get your order in today!
Old 06-22-2014, 08:30 PM   #4
Corvette7Tuning
All Afe cold air intake orders for the 2014 Corvette have been fulfilled and shipped.
We now have plenty in stock. Get yours today!
http://www.corvette7tuning.com/afe-c...stingray-.html
Old 07-07-2014, 09:05 AM   #5
Corvette7Tuning
Just released: AFE throttle body spacers for the 2014 - 2015 Corvette Stingray.
The Serrated/Helix design creates air turbulence in the intake manifold. This turbulence increases the air pressure in the combustion chamber resulting in increased horsepower, torque and improved throttle response. The Serrated/Helix combination design also reduces intake whistle that occurs with other helix only designs.
http://www.corvette7tuning.com/2014-...dy-spacer.html
Old 07-17-2014, 10:46 AM   #6
Corvette7Tuning
Newly released Afe cold air intakes for the 2014 + Corvette Stingray are computer designed to give your engine maximum air flow, which translates to more horsepower, torque and better fuel efficiency. This AFE CAI kit completely replaces your 2014 Corvette C7 restrictive stock factory air box and paper filter elements with a high flow AFE filter assembly for an increase of horsepower and torque at the rear wheels.
- See more at: http://www.corvette7tuning.com/afe-c....BspXWriZ.dpuf
Old 09-07-2014, 09:13 PM   #7
Corvette7Tuning
check out the how to install video for the afe cold air intake on the 2014 - 2015 Corvette Stingray
Old 11-07-2014, 01:33 PM   #8
Corvette7Tuning
We just got a shipment of AFE cold air intakes for the 2014-2015 Corvette Stingray. Get yours today!
Old 11-25-2014, 09:55 PM   #9
Corvette7Tuning
Black Friday and Cyber Monday specials on the afe cold air intake for 2014-2015 corvette. We have only 30 in stock. Get yours before we run out.
Lowest pricing anywhere.
Old 12-29-2014, 10:32 PM   #10
Corvette7Tuning
Special pricing on afe intakes extended until December 31st
Old 01-06-2015, 07:23 PM   #11
Corvette7Tuning
Sales ends tonight. Get your order in!
Old 03-22-2015, 07:29 PM   #12
Corvette7Tuning
Spring is upon us! Pick up a cold air intake for your C7 Corvette. Our afe and k&n kits are both in stock.
2014 corvette cold air intake
