dave@hennessey
Old 05-28-2022, 11:34 PM   #1
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Wtf BMR
So am I missing something here ? I was adamant to bmr that I had a zl1 - so why the problem with last bushing .. smh I thought bmr had their stuff together ..
Can I cutt the bushing to be able to fit in ? Or am I just screwed cause of bmr sent me the wrong stuff ..
Man I’m getting tired of dealing with parts guys
Any insight to this I would appreciate it . As my diff is sitting on the floor till I figure this out
Risingson05 is offline   Reply With Quote
Old 05-29-2022, 12:25 AM   #2
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
The diff bushings for the SS and ZL1 should be the same. They likely just need a little lube and pressure and they’ll go right in.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 05-29-2022, 12:52 AM   #3
Risingson05
Drives: 2015 zl1 m6
Umm the lip of the bushing get in the way and won’t let the bushing line up with the hole
And tbh I’m installing the delrin cradle bushing kit as we speak and I’m almost regretting buying them
, cutting off and reusing the top hat of the stick bushing and cleaning the rubber off is the pain in the ass !! Imho bmr could of done a better job , like Hendrix or some sort .. I’m pretty pissed off at bmr
Old 05-29-2022, 01:06 AM   #4
Risingson05
Drives: 2015 zl1 m6
Hmm bmr has crappy direction , they don’t even stay where to cutt the top hat so I cutt in the middle , and it’s almost square instead of round .. smfh
Old 05-29-2022, 05:52 AM   #5
Risingson05
Drives: 2015 zl1 m6
So the front cradle you have ti cut the top hat flush , the rear you’ll see when you cutt the rubber off where to cut the top hat apart at .. sure would of been nice if bmr would include that in the instructions ..
When knocking in the diff bushing I noticed that one of them was letting go alittle bit of skin , guess it kinda scraped some off . Which kinda mind boggles me as I cleaned and sanded the hole down and made it smooth ..
Unless someone here knows what’s going on I won’t be able to out my diff back until Tuesday when bmr opens up . What a bunch of bullshit
Spend 1200.00 for some rubber and you’d figure it wouldn’t be a problem !! I mean this isn’t a new product
Old 05-29-2022, 09:06 AM   #6
Risingson05
Drives: 2015 zl1 m6
Looks like ss and zl1 have different a diffs ..
Old 05-29-2022, 09:45 AM   #7
Risingson05
Drives: 2015 zl1 m6
Take it from me , trailing arms and toe rods are ok from bmr but for bushings I’d go somewhere else ..
Unless you don’t mind doing more work than you have to ..
I mean look at the mess cutting the bushing apart left
Old 05-29-2022, 02:00 PM   #8
gsxrturbo
Drives: 2010 ss
just taper the end of the bushing with a grinder and use ready rod to pull them in
gsxrturbo is offline   Reply With Quote
Old 05-29-2022, 02:11 PM   #9
Risingson05
Drives: 2015 zl1 m6
Now that’s a damn good idea thank you
Old 05-29-2022, 02:50 PM   #10
SaReNi
Drives: 2012 SS
sometimes freezing it will shrink it enough to fit.
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 05-29-2022, 03:26 PM   #11
Risingson05
Drives: 2015 zl1 m6
Yes freezing them is good idea but unfortunately In my case it doesn’t shrink them enough .
Tapering the end should do the trick .
Old 05-29-2022, 04:46 PM   #12
diddies
Drives: 2013 ZL1
Put a clamp and a washer on there and crank it down. They will go in.
diddies is offline   Reply With Quote
Old 05-29-2022, 08:51 PM   #13
Risingson05
Drives: 2015 zl1 m6
Got it done ! I ended up having to put a 1/8 notch on the lip of the bushing after tapering the end down alittle . I went and got a piece of 3/4 all thread , 3/4 washer and 1 1/2 washer 3/4 nuts , did the trick .
Old 05-31-2022, 07:53 AM   #14
Full_Spectrum
Drives: 2013 ZL1
To anyone reading this thread and looking at the BMR stuff- consider using Detroit Speed.
Yes, the Detroit Speed stuff is more expensive. It is also much nicer is every way.
Full_Spectrum is offline   Reply With Quote
