Old 04-09-2024, 02:29 PM   #29
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Originally Posted by SSE 4 2SS View Post
Interesting… I ran a one piece aluminum shaft and never had an issue..
Dead hooked at Indy hard enough to twist a 300 M input shaft as well as the main shafts inside the trans… didn’t bother the driveshaft… I’m not saying anyone is wrong, just a different set of experiences I guess…
Definitely, maybe it was because mine was built during Covid, but I twisted it in half at a lot less power. Looked to me like the weld penetration was bad and it was taken care of, but it makes me skittish toward a 3.5" aluminum shaft.
Old 04-10-2024, 09:58 PM   #30
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I received the driveshaft back and all the weights were replaced and a different glue was used. This adhesive is gray and slightly tacky, unlike the tan glue you can see in my original post.
There's something that just kind of irks me though. When I talked to Jordy (the son) at GulfCoast he said the glue they used on the CF shaft to u-joint yoke tube was the new stuff and they had only used the glue that failed on the weights, not the tube. The issue I have is I can see the color of the glue in the tube and it's tan, not the more flexible gray. There's fill holes on the end of the yoke to insert the glue nozzle to fill during assembly and some is on the outside of that hole. Not saying he bold faced lied, but it sure looks like the old type of adhesive was used on all of it. I'm glad I had him torque test it. I hope this thing holds up whenever I get the 427 put in.
I'll report back if I have vibration problems, but I don't expect any. The driveshaft was indexed to go back in the same way and the new hardware is weight balanced.
FasNuf is offline   Reply With Quote
Old 04-12-2024, 04:01 PM   #31
FasNuf
FasNuf's Avatar
Ok, well to finalize the thread,, I installed the shaft and all seems fine up to 100MPH. No abnormal vibrations or sounds.
Old 04-12-2024, 05:29 PM   #32
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Glad it worked out for you. Instills confidence that there are still some companies that will stand up for what they sell.
0stones0 is online now   Reply With Quote
Old 04-12-2024, 06:12 PM   #33
FasNuf
FasNuf's Avatar
Yea, overall they did a great job making it right and quick too.
Old 04-13-2024, 12:06 PM   #34
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome Mark!! Lets just hope this set of weights STAYS on for you!! Glad you got it all worked out!!
Old 04-13-2024, 02:51 PM   #35
FasNuf
FasNuf's Avatar
Thanks Wayne, I feel good about the weights, just not so sure they don’t have the old style glue for the tube. Goals are 1000 whp with slicks. We’ll see if a dead hook doesn’t spin the yokes inside the tube. 😳
Old 04-17-2024, 09:47 AM   #36
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome! But lets hope THAT doesn't happen!! Good luck, and have fun, and by all means, be careful..
Old 04-18-2024, 01:56 AM   #37
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Damn the carnage… My drive shaft was a 4” one piece unit… I’m glad I never suffered that which you did… That would have assuredly had me looking for something else… and skittish as well… I fully understand your comment too…
I don’t know what ultimate RPM mine was turning, (I suppose simple math could determine that) but it served me well, to speeds in excess of 225 mph… never missed a beat… Spinning tires in 5th gear at over 200 occasionally…
You might have hit on it being a Covid build, maybe premium tubing wasn’t available… and a substitute was used…
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 04-18-2024, 06:10 PM   #38
camguynj
camguynj's Avatar
Damm What size rear ?
Old 04-18-2024, 10:49 PM   #39
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
9” with 3.07 gearing… She was a bit peppy…
Old 04-21-2024, 05:32 AM   #40
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Glad they that got fixed up for you! has to be a relief for sure!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
