Vararam
Old 02-13-2020, 02:36 PM   #1
cmack
Drives: 2011 Camaro SS
Should I replace the slave cylinder?
I have a 2011 SS m6 (65k miles). The engine is out and wondering if I should just go ahead and replace slave cylinder? I thought I read about slave problems from the early 5th gens? I have not had a clutch problem but It would be my luck for it to go out after the car is back together.
cmack is offline   Reply With Quote
Old 02-13-2020, 03:08 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I would.
Old 02-13-2020, 03:37 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Easy time to do it. Why not!
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 02-13-2020, 04:57 PM   #4
cmack
Yup that is what i was thinking
Old 02-13-2020, 06:09 PM   #5
cmack
Big difference in prices on #24266013
Summit has it at $432
GM Parts Direct $285
Tick Performance $278
Rock auto $146
As far as I know #24266013 is the updated on for all v8 manuals. Is there some reason I should not get the $146 one from Rock Auto?
Old 02-13-2020, 08:27 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Rock auto $146
LUK makes them for GM.
More to come.
Black_SS10 is offline   Reply With Quote
Old 02-13-2020, 08:38 PM   #7
cmack
Thanks!
Old 02-14-2020, 10:01 AM   #8
RankSS
Drives: 2010 Camaro SS
Get a billet bearing support from Monster or Tick and ditch the plastic one in your new slave.
Monster sells new slaves with the billet support already installed if you prefer.
A remote bleeder is a good idea too.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 02-14-2020, 10:12 AM   #9
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Bingo pretty much must have items on these cars especially when trans is dropped out.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 02-14-2020, 02:52 PM   #10
cmack
Bearing support and bleeder already ordered from monster! I ordered the LUK slave from rock auto for about $150
Old 02-17-2020, 10:42 AM   #11
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Hey guys, just confirming that if one plans to pull out the transmission to replace the clutch, replacing the slave isn't necessary, but a "might as well". Correct?
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Cornflakes'Camaro is offline   Reply With Quote
Old 02-17-2020, 10:59 AM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
Yes. lf it ain't broke don't fix it. BUT, since your there it is easy to do. I've reused mine plenty of times with no problems. Just make sure to check the throwout bearing for excessive wear and be sure it spins freely. It pops right off, so you can grease it as well.
More to come.
Old 02-17-2020, 02:10 PM   #13
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
I got the billet ram slave no plastic at all, did this when my old Gm slave went to shit and blew my master cylinder as well. honestly while you’re in there do a tick billet master cylinder and ram slave and be done with it. Heat kills and I learned the hard way lol.
_Onyx_Wolf_ is offline   Reply With Quote
Old 02-18-2020, 08:56 PM   #14
Cornflakes'Camaro
Roger that. Thank you gentlemen!
