TireRack
Old 04-27-2013, 09:37 PM   #1
purv24
Drives: Black 2ss
SLP LTs, xpipe, and loudmouth 2 question
Just had all these installed... sounds awesome but I have a question.
The crossover plate is touching the resonators... is this install error? Is it normal for it to touch? Can I remove the plate?
I just dont like the Idea of the plate rubbing on the resonators... any help would be appreciated.
purv24 is offline   Reply With Quote
Old 04-28-2013, 12:01 PM   #2
Juice2SS
Drives: 2011 2SS
It will bang on that. There are a few companies that make one that is made for 3" exhaust. They aren't too expensive either.
Juice2SS is offline   Reply With Quote
Old 05-01-2013, 10:58 PM   #3
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I used a 3/4" thick aluminum block cut to fit the mounting brackets. Painted black and drilled the same as the bolts that I bought at home depot. Those resonators need clearance, I'll post a pic of what I have if you like.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 05-05-2013, 02:05 AM   #4
purv24
Drives: Black 2ss
that would be awesome if you posted a pick bro.
Old 05-05-2013, 08:45 PM   #5
tjbusa
Serious Sleeper
tjbusa's Avatar
Best I could do for now without jacking the car, but this set up gives me 1/4" clearance between the brace and the resonators.
Drive-by
Fact of Life:
W T F
Old 05-05-2013, 09:59 PM   #6
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
Nothing should the exhaust but rubber or the noise will travel into the cab. Don't remove the tunnel brace. The chassis will flex on a hard take off.
2010/2SS/RS/6L80E/Mast built LS3 416 Stroker/Black Lable Heads/Blower Cam/Jannetty Tuned/ 685rwhp/635tq/KookHeaders/3"exhaust/Magnaflows/Whipple Blower/10lbs bst/Duel pumps/85lb inj/2 gauge pillar/CAI/RX catch can/Vmax ported TB/Lexani LX15s/Pedders sub F bushings inserts/Pedders sport extreme coilovers/ZL1 sway bars/Hotchkis strut tower brace/Hawk brake pads/stainless steel brake lines/CTV front calibers/slotted rotors 15"/1 pc drive shaft & loop/hidden radar-laser detect/rear louvers/terminator hood/ SS mats/black outs/Bowties/GM GFX kit/blade spoiler/deading matting/wolf art/
Camaro54 is offline   Reply With Quote
