Go Back   CAMARO6 > CAMARO6.com General Forums > Photos | Videos | Renderings
BeckyD @ James Martin Chevy
Old 08-24-2016, 06:41 PM   #57
H(.)(.)ters
H(.)(.)ters's Avatar
Drives: 2SS - Black
Any cutting involved to get those 5-spoke wheels on with 25mm all around? I want to get the exact setup. Let me know where I can order a set please.
H(.)(.)ters is offline   Reply With Quote
Old 08-24-2016, 07:10 PM   #58
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
I actually assisted Richard with those spacers. They were the ones I ran from my SS when i had the stock solid 5 spokes.
So here is the scoop!
The Solid 5s, require NO trimming of studs to run 25mm spacers.
The twin spoke 5s do require trimming, and quite a bit. The rears more than the fronts as well.
The pockets in the back of the twin spoke 5s are not as deep as the solid 5s.
Fortunately you don't have to trim down into the threaded area on the studs, it has enough meat on it still.
If you are doing it yourself, I will let you know it will take about 2-3 hours with an angle grinder to do all 20 studs.
Team STILLEN is offline   Reply With Quote
Old 08-24-2016, 07:14 PM   #59
H(.)(.)ters
Drives: 2SS - Black
The twin spoke 5s do require trimming, and quite a bit. The fronts more than the rears as well.
Thanks. I have the solid 5's (see my avatar). So, I think I'm good to go. Where can I order a set?
Old 08-24-2016, 07:15 PM   #60
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
...and to be crystal clear, the solid 5-spoke wheels require no/no trimming of studs, correct?
ride98red is offline   Reply With Quote
Old 08-24-2016, 07:16 PM   #61
Team STILLEN
Drives: Varies
Yessir, I had the silver solid 5 spoke wheels on my SS.
No trimming required with EIBACH 25mm spacers.
Old 08-24-2016, 07:17 PM   #62
Team STILLEN
Drives: Varies
You can give me a call and I can take care of you!
Old 08-24-2016, 07:20 PM   #63
H(.)(.)ters
Drives: 2SS - Black
I just emailed you.
Old 08-24-2016, 07:29 PM   #64
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Haha Joe, hopefully you NEVER HAVE TO go through that again!!
Richard0nee is offline   Reply With Quote
Old 08-24-2016, 07:35 PM   #65
Richard0nee
Pretty much.. u guys are lucky!! Lol
Old 08-24-2016, 07:52 PM   #66
ride98red
ride98red's Avatar
I almost asked the dealer to switch my wheels for the split 5-spoke. Glad I didn't. I really want Ferrada FR1's but not in the budget yet. Spacers will hold me over for a bit.
Old 08-25-2016, 02:33 PM   #67
BMR Tech
BMR Tech's Avatar
Drives: 2016 Camaro 2SS
Does this count as aggressive?
As mentioned, it appears our current spring will have no adverse affects when used on an MRC car
BMR Tech is offline   Reply With Quote
Old 08-25-2016, 02:37 PM   #68
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Or just run spacers and longer studs.
BradfordCamaro is offline   Reply With Quote
Old 08-25-2016, 02:42 PM   #69
Richard0nee
Yes sir it does!
Rim/tire/stance combo looks GREAT!
Old 08-25-2016, 02:54 PM   #70
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Looks aggressive and functional. What size rims and tires are those?
drivingagain is offline   Reply With Quote
