Roto-Fab
Old 02-11-2016, 10:37 AM   #1
Wizzer
Drives: 2010 Cyber Grey
Anyone notice your 2010 car bogs out in heavy rain?
I have been noticing the last year or so when it rains heavily the car will bog to the point of stalling when in highway use. I had to limp over to the side of the road during a heavy rain storm.
I popped the hood and looked around but nothing was too obvious.
I originally thought the hydro shield on my Injen CAI was faulty and I was sucking in water.
Funny enough when I restarted the car on the side of the road it worked fine 5 minutes later. Ran perfect and when I drove out of the rain storm all was well. Never does it on dry days.
No codes pop it just stalls out.
Hydro shield looks good. No holes and its in good shape.
All I can think is water is getting into a electrical plug in or something.
Anyone have or solve this issue?
Thanks
Wizzer is offline   Reply With Quote
Old 02-12-2016, 04:52 PM   #2
Amistad2011
Drives: 2011 Camaro 1LT\RS
I instantly think traction control, just a simple guess.
Amistad2011 is offline   Reply With Quote
Old 02-12-2016, 08:17 PM   #3
Wizzer
Hmmm. That's very interesting. But that would be dangerous. To have a car bog to the point of having to slow down and then turn it off to get it to reset. I'll keep your idea in mind but I am not sure.
Old 02-13-2016, 02:48 PM   #4
Wizzer
Yeah I am still leaning towards that. Thx for your input.
Old 02-15-2016, 03:01 PM   #5
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
I think the hydro seal only can take so much . I stay at low rpm during the rain to avoid sucking in air .
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 02-16-2016, 03:32 PM   #6
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
This has happened twice to me. It seems like the water is blocking the sock allowing proper air to be supplied to the engine. The engine is stalled on lack of air for combustion. I made sure the sock was good and not leaking into the intake. From the obd data on fuel trims it looks like the engine tried to adjust.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 02-16-2016, 03:41 PM   #7
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Thanks
Not on a Camaro but the exact same thing on my bike. Turned out to be a bad electrical connection. If it's electrical. It's a bear to chase down.
Thor142 is offline   Reply With Quote
Old 02-16-2016, 06:41 PM   #8
Wizzer
That sounds very likely. All failures were at highway speed and I remember that I got a huge wave of water from a semi that slapped at my windshield and I hit the gas to get around him and it bogged. I almost got hit from behind as I slowed down rapidly by the engine failure.
I can see the water standing on the hydro shield and not being able to suck enough in for combustion.
Thanks for that input.
I guess that's what happens when you mod a car from the original intent.
I will keep the rpms low in the slow lane next rain storm and I will see if I can get through it.
Old 02-17-2016, 02:22 AM   #9
rwi2112
Green Manalishi
rwi2112's Avatar
Drives: 2010 Synergy Green Camaro LT
LOL
My Baby has 17k miles. I don't drive it in the rain Good Luck though
rwi2112 is offline   Reply With Quote
Old 02-18-2016, 02:54 PM   #10
Wizzer
I hope to get to that stage of my life someday.
It not yet. lol
Old 02-19-2016, 01:01 AM   #11
rwi2112
Green Manalishi
rwi2112's Avatar
My new Silverado is black so I really don't like to take it out. Thank goodness for the wifes Fusion ;-)
Old 02-22-2016, 12:52 PM   #12
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
I drive mine in the rain and it's never caused me a problem on a 50 mile round trip commute however I do have a mazda pickup that would stall out and run like hell when it snowed a wet slushy snow. This problem puzzled me and my mechanical type friends for a few winters but it went away when I replaced the distributor last summer. Therefore I am in agreement that it could be an electrical problem.
Tori
click the sig pic to view my build thread
heRS is offline   Reply With Quote
Old 02-23-2016, 08:12 PM   #13
Wizzer
Ok it pooed out on me again but I was running my app and had the obd dongle beaming live stats to my phone that was mounted on the dash.
I attached the picture of the codes it popped. Ignore the top one... that's a known issue and I am waiting to get that fixed.
I was driving in rain today from Alabama to Florida and I purposely tried to keep the rpms low on cruise control in the slow lane.
The car started to go up the hill and down shifted. bogged out like crazy. The codes say it miss-fired. Only fix is to make sure nobody is behind you. Put it in neutral. Turn it off for 2 seconds and turn it on. Fixed the issue then it bogged again. Slowed down more and re started it. Milked it up the hill and did about 60 till the road dried. Once the rain stopped it ran perfect. Passed perfect. All the power was back.
I think when it started to suck in air on the downshift the hydro-shield on the Ingen was doing its job and it couldn't flow the air into the engine and caused a misfire. The water must have restricted the airflow on the top of the shield. Good news the shield works.
The road was flooded and I actually was trying to baby it driving on the higher parts of the road.
Thoughts?
Old 02-23-2016, 08:41 PM   #14
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
You answered your own question. Sure the INJEN hydro-shield stops water from getting sucked in, but it also blocks air when it's covered with water. I'd look into a different cold air intake if I were you. JMO I wouldn't drive a car that doesn't operate correctly when it rains, unless it was a race car.
Eddiefuzz is offline   Reply With Quote
