Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 12-23-2015, 08:26 PM   #309
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
That's great ! I ended up soldering the connections also. The crimping of connections on the early kits were not a good way of extending the harness.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 04-29-2016, 04:45 PM   #310
strtsol1109
Drives: ZTS pearl in autoflex
Getting a good bit of squeak from my used SC belt after install, does anyone have the part number for the gatorback??
Full MBRP 3in exhaust, Vitesse TC, BBK LT, black iceolator, VMAX TB, vararam, LG coils, zl1 reps, zl1 front bumper, zl1 grille, zl1 rockers, CF Copo hood, CF trunk, gm blade wing, HAVOC diffuser, APR splitter, dipped SS calipers
strtsol1109 is offline   Reply With Quote
Old 04-30-2016, 07:27 AM   #311
Lombardi
Lombardi's Avatar
Drives: 2010 ABM Camaro 1LT
Check your tensioner as well. That was my problem.
Sent from my SM-N910T3 using Tapatalk
Lombardi is offline   Reply With Quote
Old 04-30-2016, 10:22 AM   #312
strtsol1109
ordered one just in case! still cant find a gatorback PN anywhere
Old 04-30-2016, 02:48 PM   #313
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
061075 or 061073 but that was the lfx motor. Look on your belt for the number
http://www.amazon.com/Continental-El...+Elite+4061073
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 04-30-2016, 02:49 PM   #314
sycraft
COTW 5/06/2013
sycraft's Avatar
http://www.summitracing.com/parts/cel-4061073
Old 05-01-2016, 04:59 PM   #315
strtsol1109
wouldnt the etrxa .25 inch slack be too much?
thanks for the links/help
Old 05-01-2016, 05:02 PM   #316
sycraft
COTW 5/06/2013
sycraft's Avatar
depends on the car, mine was best with the 61073, but it came with the 61075
Old 05-03-2016, 09:14 AM   #317
jimmyp
Drives: 2013 Camaro Convertible
Were you getting slippage with longer belt?
jimmyp is offline   Reply With Quote
Old 05-03-2016, 09:37 AM   #318
sycraft
COTW 5/06/2013
sycraft's Avatar
Yes
Sent from my SM-N920P using Tapatalk
Old 05-07-2016, 09:57 PM   #319
strtsol1109
Well it was the bearings not the belt, got the boca angulars and its all good now! What snow kit for meth have you guys been using? Assuming it's the stage 2 MAF/MAP
Also how loud is everyone's supercharger at idle/high idle (1000-1500) rpms? My bumpers still off but I feel like it's screaming!
Also has anyone ever had any issues while highway cruising, it feels like the throttle keeps going on and out when I'm holding it at a constant speed. I turned off the VTC controller and it helped a little but still not normal?
Old 05-08-2016, 06:58 PM   #320
HeritageLS
HeritageLS's Avatar
Drives: 2012 1LS Camaro (Victory Red)
Yeah not normal. Mines solid at cruising. And at low rpms it's pretty silent. I had the idle issue but that was fixed by Matt @ FSP giving it a good tune
HeritageLS is offline   Reply With Quote
Old 05-09-2016, 07:00 PM   #321
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Add the screw information to the first post if you need replacements. The Supercharger Head Unit Screws are the screws that hold the head unit to the bracket, you will only need to take this off if you are doing a rebuild of the head unit. Numbers in parenthesis are the amount required. 10.9 is the minimum grade I recommend, not Stainless A2 or 8.8. 12.9 is ideal.
Supercharger-Engine Bracket Screws:
M12 x 50mm Flat Head Socket Cap Screws (2)
M12 x 70mm Flat Head Socket Cap Screws (1)
M12 x 80mm Flat Head Socket Cap Screws (2)
M10 x 20mm Flat Head Socket Cap Screws (2)
M8 x 60mm Flat Head Socket Cap Screws (2)
M8 x 45mm Socket Head Cap Screw (3)
Supercharger Head Unit Screws:
M12 x 20mm Flat Head Socket Cap Screws (2)
M12 x 40mm Flat Head Socket Cap Screws (1)
M10 x 75mm Flat Head Socket Cap Screws (2)
M8 x 30mm Flat Head Socket Cap Screws (4)
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 05-10-2016, 11:03 AM   #322
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Good Information Magnum, I'm definitely glad I had replacement bolts when I needed them.
