08-18-2013, 12:21 AM | #169 | |
Probably just bore it enough to get it nice and clean new. |
08-18-2013, 12:25 AM | #170 |
Keep in mind the engine had 95k miles on it.
Only three of the main cap bearings came up not blurry. All 5 bearings came up on the block. Few pics of what the typical wear seems to be on all of it. I'm still not sure I found where the oil pressure was lost. What say you guys? In order 1-8 rod caps then 1-8 rod mains. Last edited by PQ; 08-18-2013 at 01:14 AM. |
08-18-2013, 12:46 AM | #171 |
BTW, in this pic the yellow arrows point to the oil flow holes in the cam bearing. All 5 of them have both holes in the bearing.
But the hole with the red circle does NOT have a oil channel under it. It is just the block seat under it. It is this way on all 5 cam bearings. I'm assuming this is normal? |
08-18-2013, 07:30 AM | #172 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
While I think it's awesome to be sharing all of this and I love to see the pics and learn...those guys at Livernois are top notch. Tell them your goals and trust them to put what u need together. End of story.
-John S.
08-18-2013, 11:55 AM | #173 | |
Anything I buy will be bought and speced from them. But I don't have the 10k right now that it will take to buy a long block. I am exploring a way to use what I can and make a solid build while I save for a whole new engine. Might just end up building a really solid engine. In the coming weeks I will know. I have a trip to Utah this next week so the week after I will get with Livernois and begin this build. |
08-18-2013, 02:18 PM | #174 | |||
just can't seem to leave
i'm surprised nobody's shown this yet with all the talk of blower efficiency on xxx cubed engine. i'll warn you, it takes some post-elementary math to figure out the CFM number to use, but once you find out how much air your target engine will move (through cylinder volume, compression, head flow, etc), this chart will show you the target boost level to shoot for & what RPM you have to turn to achieve that.
from what i understand, the sound is created from the air being compressed into the valley by the belt, and if you alleviate that pressure, you lose some of the sound. that's what i've seen on a couple cars, anyway. that way, you get the quiet, wussy-sounding operation & get to eliminate any rear belt slip - which, as Jamie mentioned, starts becoming an issue above 10psi on the factory 10rib rear. then there's also the gargantuan LPE 14-rib contraption that also works quite well & has it's own independent tensioner to keep the strain off the jackshaft. it just requires a lot more room & money than a cog setup. either way you choose, if you're looking at 10+psi, you might need a 8rib front drive anyway. i know i was slipping a good bit @ 11psi with my stock 6rib Quote:
to be honest (more for $$ reasons than anything now), i'm looking at 382/383 kits for my LS1 now, but i just ain't convinced yet if it'll make the top end i want. i'm pretty sure 700+ tq to the ground will be easy, but 700+ hp will be the hard part because with an undersquare engine, the power is gonna come on pretty early & i wouldn't want to spin it more than 6500. that means i'm gonna need some magical heads and a top-heavy cam - which will be blowing more of the boosted air right out the tail pipes. life sure is hard trying to make big numbers with an LS1 & a PD blower Quote:
not that far out of the way... just sayin'
Eve ('00 FRC): hot-air intake
Rowan ('09 H3): 5spd mom-mobile Penny ('99 Sierra): 5.3 / HD 5spd... gone but not forgotten Samson ('18 HD): compounded 408 |
08-18-2013, 03:17 PM | #175 |
PQ must be dang hard on this car with all the issues he has had. I just go thru back tires, he breaks everything.
08-19-2013, 08:56 AM | #176 | ||
Struts - Savini LCAs - Savini Drive shaft bearing - Savini Wheels/Tires - Savini Engine - Comp cam/Vengeance |
08-19-2013, 11:28 PM | #177 |
all fair points. have fun!
and yes, i'm alive
09-06-2013, 09:33 PM | #178 |
Found a local machine shop. gotta get with Livernois for some advice.
09-06-2013, 09:43 PM | #179 |
Drives: 2010 Camaro Join Date: Feb 2010
They Livernois mini stroker looks like a great option. Just so you know, mine is a brand new, top of the line parts build, hell the rods were $1550, and even with a new ls3 block its over $12k so far. The engine isn't even done being built. That's the up to date estimate as of 4pm today. I know because I just dropped off the cash.
Take you time and shop around. Get with Matt at FSP if you need help with parts. Getting a ready to go short block will save you tons. |
09-09-2013, 01:43 AM | #180 | |
Ya, I'll know more soon. If it becomes cheaper to let Livernois do the entire thing then I'll do that. But I'm going to get a cost of having my crank and block done here. Found a really good shop finally. Had to go to the local racers. hahaha Crank could maybe be turned and redone and I can have the block bored as well. If the savings is worth it I'll have Livernois send me some forged pistons and rods and a cam with the valve train parts. Sure I'd like to just throw it all away and buy a bulletproof engine but I can't do that. I'll still end up with a much stronger engine than it was. |
09-09-2013, 10:51 AM | #181 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
I'm glad you are making at least some mental progress here PQ
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
09-09-2013, 11:47 AM | #182 |
Drives: 2010 Camaro Join Date: Jun 2009
PQ let me know the plans sir. Lets help you get this thing back on the road
